Loader for a series 4 D17.
redowns View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redowns Quote  Post ReplyReply Direct Link To This Post Topic: Loader for a series 4 D17.
    Posted: 14 Nov 2022 at 8:19am
I am wanting a loader with a hydraulic bucket for my series 4 D17.  What loaders will fit and where might I find one.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 9:10am
I have a Series II D-17 with a 500 loader, and it works great.  When the dealer installed it, in 1970, the axles and tires were upgraded to a larger size than standard.
The frame rail width of a D-17 is slightly narrower than on a 180 tractor. The D-17 requires a shim between the frame rail and the loader frame.
I believe the Series IV does not require a front pump. I am sure someone will give verification regarding the pump.
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2022 at 3:20pm
Schwartz, I think it is a model 1400
Edited by Stan R - 14 Nov 2022 at 4:24pm
orangepeeler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangepeeler Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 9:53am
I've got an old Westendorf loader that has been off my D17 S4 for a few years now. My 17 has a narrow front end. I've always wondered if there was a simple way to mount it on a wide front. It doesn't look much different than Stan's. Stan could you tell us how you drive into the Schwartz?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2022 at 1:48pm
Orangepeeler: it is a late '60's style. And not really an easy on/off unit, though it could be taken off in maybe an hour. It has no "jack stands", etc. Plus we would need to add some quick connects for the hydraulics if we ever took it off as currently, every connection is threaded. It's one of those things that we just leave it on as its not much of an hindrance with it on in our opinion.
This page was generated in 0.093 seconds.
