Loader for 6080 |
LB0442
Topic: Loader for 6080Posted: 23 Oct 2017 at 9:11am |
Mine came with a factory loader. When I need a remote I let the bucket drop so there is no pressure on the lines and unhook that set of remotes to use. If I need both it is fairly easy to unhook the loader with the factory stands. I think eventually I will set up a joystick on the power beyond, just haven't really needed to yet. Our local tractor salvage has a selection of loaders, maybe check in your area?
WNYBill
Posted: 22 Oct 2017 at 8:24am |
Found a 6080 4WD but it has no loader, where would I start looking and how much should I plan on spending? Otheres I have seen plumb into and operate by the rear remotes, how do you use the remotes if you have the loader on?
This tractor has no muffler, only a chrome pipe, good or bad? Also has 18.4 x 34 rears, it has < 2000 hours showing, so did they come that way? Or should I be suspect of the hours? Bill
