Loader bucket pin bore diameter
structures View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote structures Quote  Post ReplyReply Direct Link To This Post Topic: Loader bucket pin bore diameter
    Posted: 01 Jul 2024 at 10:25am
I’m making a spear for the 500 loader. When making the bracket bores for the pin anybody got an idea for the diameter? It’s a 1” pin. I measured an old lightly used allis bucket at 1.02”. Some pins I measured were an 1” or even a few thou over an 1”.
Anybody got advice? Thinking of going 1 1/64” drill bit.
Randy Magnum View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy Magnum Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2024 at 10:50am
I machine parts for tongs and lifting devices quite often, and .015 is the common clearance.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 7:56am
When I built a quick attach for my WD45I used a die grinder and just got them to fit.
It keeps the slop out of it.
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 8:14am
best go 1/16" more as you have 4 pins to lineup and I bet the frame ain't 100% laser level perfect ??
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2024 at 8:16am
X-2!
This page was generated in 0.182 seconds.
