Live Hydrolics for a C |
Page 12> |
Author | |||||||
AJ ![]() Orange Level ![]() Joined: 31 Oct 2010 Location: mo Points: 5244 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Feb 2012 at 6:31pm |
I am planning to put a loader on my allis c. I am wanting to figure out how to get live hydrolics on my tractor to run the loader. I don't want to cut my tractor's grill up or any other sheet metal. So i am asking for ideas/advice. Pictures would me great if you have them.
Thanks Aj
Can't fix stupid
Sponsored Links | |||||||
allismanamp ![]() Orange Level ![]() ![]() Joined: 15 Oct 2011 Location: MN Points: 665 |
i don't know how to do the picture thing yet but i seen a very nice ca Allis a older gentleman had done up power steering on and the way he did it was clean and you would swear was factory don't ask what type of pump it was but he added it right in to the steering column and it was hid down inside the tool box looked really nice i got pictures of it on my digital camera i thought it was a combine steering
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87703 |
saw this once-- not mine
Ted in NE-OH ![]() Orange Level ![]() ![]() Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
How about a PTO hydrolic pump.
R.W ![]() Orange Level ![]() Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
But he wants "live" hydraulics.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
The C already has hydraulics that work with the PTO but they aren't live. |
1953CA ![]() Orange Level ![]() ![]() Joined: 01 Jan 2011 Location: Burlington, WA Points: 505 |
You can do Live hydraulics off of the PTO...AJ I might have just the thing for you...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support" |
If you had a CA pedestal, you could mount a pump up front, drive it from the front of the crankshaft and not have to cut any sheet metal. I don't know if there is a way to anchor the pump on a C pedestal.
No you can't. The PTO stops when you clutch the C so it's not live.
Yes that is the issue. I don't want to run it off the pto, I want to leave that open. I do like how that CA has the set up for the live hydrolics. Does anyone know what is required to do that?
Can't fix stupid
SteveC(NS) ![]() Orange Level ![]() Joined: 12 Oct 2009 Location: Nova Scotia Points: 663 |
So, is this a secret you'll only share with AJ?
Buy the rear end from a CA and bolt your engine and torque tube to it. Or maybe just buy the final drives from a CA and attach them so you have the hand clutch. Then you won't have the 4 speeds and the better hydraulic pump.
Edited by CTuckerNWIL - 11 Feb 2012 at 8:16am |
Gary ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Peterborough,On Points: 5899 |
I think the idea of 'live hydraulics' is so you can push the foot clutch and change gears while still having operating hydraulics.
So a CA axle clutch wouldn't give you 'live hydraulics'. Gary
Well that's how the CA got it, buy using the hand clutch, the PTO is live, just not independent. It wouldn't be very handy for loader use. Might be a little better if you moved the hand clutch to the left side.
Charlie
Does thst mean D-14 and D-15 have 'live hydraulics' then because they have the Power Director / Hand Clutch. Don't think so. Hand clutch disengages power to the wheels . Gary
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
It is a lot of work but I saw pictures of a setup that had a belly mount hydraulic pump run with a roller chain where the drive gear was mounted to the engine side of the flywheel. Openings have to be cut on both sides of the bell housing to run the chain thru along with a pump mounting plate attached to the under side of the bell housing. Torque tube in this case. It was plumbed to the PTO housing using the same oil as the original hydraulic pump that could still be used.
Eldon (WA) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Front pump is mounted to the front axle bracket for the WF pivot....may be a problem with a nf tractor. This setup is sweet, 3pt on the rear with 2 way cylinders.
ALLIS EXPRESS!
This year: |
Eldon's setup simular to my B, minus mine is tucked in the front grill. Which cutting up the grill maybe a down side, but if it's done clean, I think is the easiest way to get LIVE hydraulics. Just mount to the radiator support and run a shaft through the hand crank hole and your done.
dustinmo ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Auxvasse, MO Points: 2187 |
Find a behlen (I think that is the spelling) pump that fits between the mag/dist and the block, have one on my wc forklift and a 45 with loader and saw another one time that was used to power the orig power steering setup on a 45, dont have a pic but they are sweet and small and no cutting of any kind, then all you need then is a valve and a tank
YES, that is live hydraulics if you can stop the forward motion of the tractor and keep the pump running. The WD,45,CA and all D series have live hydraulics as long as the hand clutch or power director work.
Charlie
I guess it comes down to ones 'interpretation' of what 'live hydraulics' truly is. My opinion is a tractor has 'live hydraulics' only if the pump is still operating with the foot clutch depressed. My D-12 Series III has both 'live hydraulics' and 'live PTO'. Both the hydraulics and the PTO still operate even with the foot clutch depressed. What do you other knowledgable Allis guys think ? Gary
scott ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: michigan Points: 2734 |
I agree w Gary.
The WD was sold as having "live" pto....being able to stop motion without stopping the pto, in this case by using the auxillary hand clutch. The D10/12 Series III had an "independent" and "live" pto....."live" because you could stop motion without stopping the pto and "Independent" because it wasn't dependent on the main clutch being engaged for it to operate.
ALLIS EXPRESS!
This year: |
Dusty MI ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5059 |
What I liked about the type such as the WD and others used is that say you were running a PTO combine and something happened that you needed to stop every thing, combine and ground travel, one motion, the foot clutch, did the job.
Dusty
Steve, what kind of pump is that on that CA? That would be ideal for what I'm wanting.
Can't fix stupid
That's exactly why I like my 175D's for tilling and brushhogging...some people think that the hand clutch/power director isn't user friendly like the new "independent" tractors, but I disagree!
ALLIS EXPRESS!
This year: |
AJ, i dont know what kind of hydrualic pump it had. Took the photo at a show. I had layed one out once and problem is the belt tighen and alignment. This one had a double pulley on the alternator. Fan belt drives alternator, and alternator drives pump with a seperate belt.. solved a lot of problems i thought.
Tucker did they make these for the allis C? If so, how go on the tractor and how hard would it be to find one to fit an allis C?
Can't fix stupid
There is one for sale at that link. You take the magneto off, put the pump on and bolt the magneto to the pump. Plumb it up using an add on tank or the differential housing as a reservoir and add the valve you want with a return line. |
Page 12> |
