Line Hone or Shim a CA |
BlackFatbob ![]() Bronze Level ![]() Joined: 12 May 2016 Location: SWFL Points: 19 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Nov 2016 at 9:54am |
Guys, I would appreciate some opinions regarding line honing or shiming on a CA rebuild.
I'm building this tractor primarily for mowing duty with a 5 ft woods and expect to be operating at a governed rpm north of 2,000. If it were yours would you line hone the mains and recondition the rods to eliminate the shims or just shim and go? Thanks Dennis
GregLawlerMinn ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lawler, Mn Points: 1226 |
I line bored those I rebuilt thereby eliminating the shimming. Cost more but eliminated a possibility of a mistake from my limited ability.
Currently have: 1 D14 and a D15S2. With new owners: 2Bs,9CAs,1WD,2 D12s,5D14s,3D15S2s, 2D17SIVs,D17D,1D19D;1 Unstyled WC |
Thanks Greg, based on your rebuilt pedigree, it means a lot.
Dick L ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Edon Ohio Points: 5087 |
The only one of this type of engines I line bored was the one I used as a high RPM engine for my C I used for pulling a transfer sled. I just completed the 6th season mowing with a C that I put the engine together with all in spec used parts I removed from dead tractors that I bought in years past. I have pictures of the process I went thru in shimming both mains and rods. I run about 2200 RPM's mowing. If you want to put the money into line boring and machining the rods to remove shims it sure will not cause a problem. Properly shimmed will not be a problem either. Fear and the lack of understanding causes most to spend the extra money.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8452 |
If you choose to shim, Steiner's announce they were now carrying shims for those engines, just after I rebuilt mine. I couldn't find shims ANYWHERE, so I used a Dr. Pepper can... Some would probably slap me, but I got proper clearances and the tractor runs great.
I would definitely recommend getting real shims, since they are now available!
JimD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Mounds, OK Points: 2112 |
We also have the shims. You will get some pretty passionate answers here. Personally, I vote to re-shim. IT ran great that way for 60 years.
Owner of OKtractor.com PM for an instant response on parts. Open M-F 9-6 Central.
We have new and used parts. 877-378-6543 |
Fred in Pa ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
They have always been available, I always do the rods , but I only line bored a few block's in the pass 30 years of building these motors .Turn crank ,start with new shims. |
nonetheless ,still dead. If all else fails ,Read all that is PRINTED. |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21477 |
Line-boring has always been a way to salvage a block that has spun a main bearing in a main bearing bore. Whenever you do this, the tail of the crankshaft gets raised up from true center a bit. The timing gear backlash also can get a little tighter. In a salvage effort, one can live with the negatives. When there's absolutely nothing wrong with the block, why ????????????????
Thanks Dick,
That really cuts to the heart of my concern. Will the engine tolerate the rpm and load using shims, and would line honing be a waste considering the capabilities of the lube system and eventual bearing wear regardless. I appreciate the experience and input. Think I'll shim it and go.
The block seems fine, however this was a wet and frozen engine with at least two liners broken out. I was 0.006 low between 2 and 3 on the deck before I cut it. So the block might be slightly distorted. I can get a feel for that as I shim and always back track if needed.
Thanks Doc
Good point on the rods. This engine had at least two liners frozen and broken that I know of. So it might be smart to recondition them jic.
Thanks
Check the main bearing bore alignment. They can be off enough that with proper clearance your crank can be locked when you tighten the caps.
Hubnut ![]() Orange Level ![]() ![]() Joined: 30 Jul 2014 Location: Gainesville, FL Points: 1812 |
For amateurs like myself, I found it worth the little extra cost to line bore. However, after I did my first engine rebuild with line-boring, I shimmed the next 4 engine rebuilds I did with no problems.
1940 B "Lucy"
1941 B w/ Woods L59 "Flavia" 1942 B w/ finish mower "Dick" 1941 C w/ 3-point "Maggie" 1947 C SFW w/ L306 "Trixie" 1972 314H |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 53497 |
Shim stock and plastigage are real cheap, MSC, Mcmaster-car, enco, and many others sell it on line...
