Light Bracket for D12-III |
Terry/EasternIa
Joined: 27 Feb 2010 Location: Eastern Ia Points: 94 |
Topic: Light Bracket for D12-IIIPosted: 31 Aug 2010 at 8:19pm |
My brother is looking for light brackets for his D12-III. The ones that go on the fenders. And rear light bracket also.The left bracket is a grab handle also. D10, 15 &17 seriesIII are the same also. Terry.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7533 |
Posted: 31 Aug 2010 at 9:55pm |
Good luck, they are very hard to find. Try searching through tractor wrecking yards and you may get lucky.
JoeO(CMO)
Joined: 11 Sep 2009 Location: Cent Missouri Points: 2696 |
Posted: 02 Sep 2010 at 6:06am |
I have a D10 III which was missing the rear work light. I found one after 20 years of looking,,,,walked by this hardly recognizable partial skeleton of a tractor(a I400) and there it was-a light complete with fender bracket and original hardware, no dents, but wiring had been repaired and length was ok. It was as if someone put that light right where I could see it! I had been through this salvage a few times looking for other items and hadn't seen it before. I had a D15 fender bracket that I ground the bottom so it would set on the D10 III fender, used it until I found the correct one.
Edited by JoeO(CMO) - 02 Sep 2010 at 6:08am |
armandjones82
Posted: 21 Jan 2011 at 8:35pm |
If there are any other way that brands like kc hilites and other brands can fit to that, then it would be much better to really have that one in order to make things well on your light bracket needs. If not, then try to resort it to other options in order to make things work out.
Edited by armandjones82 - 21 Jan 2011 at 11:40pm |
Ray
Posted: 22 Jan 2011 at 12:41pm |
i WOULD HAVE LIGHTS AND BRACKETS BOTH FOR THAT TRACTOR. 785-353-2392
acdeerboy123
Posted: 22 Jan 2011 at 8:08pm |
need fenders for a d-12 series III
