less battery
Marlyn nwia View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Marlyn nwia Quote  Post ReplyReply Direct Link To This Post Topic: less battery
    Posted: 12 May 2025 at 1:31pm
will a D-15 II gas continue to run with no battery but was pulled to rotate engine?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 1:34pm
If it has a properly functional generator it should, if it has an alternator, probably not
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 3:36pm
the battery is part of the "VOLTAGE REGULATOR" system.. When you disconnect the battery, the generator (12v) can put out around 20 volts because it has no feed back regulation... You could blow the head lights if turned on.. I dont THINK it will damage the COIL... but not guarantee..... your further ahead to have SOME TYPE of battery in the system, even if its not in very good shape.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2025 at 7:23pm
I believe the D-15 uses an actual voltage regulator rather than the simpler light switch method of the earlier tractors; if so, it 'should' keep the voltage under control.
Agreed that it is better to have a weak battery rather than none, but you certainly do not want one in there that has a shorted cell.
This page was generated in 0.039 seconds.
