Leaking A II variable drive
Message Reverse Sort Order
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Topic: Leaking A II variable drive
    Posted: 29 Apr 2010 at 10:26pm
Thank you both!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 5:35pm
You've got to get some kind of a puller on that outer sheave and get it yanked off of the shaft first...after that I think it's easy....replace any brgs that got oil on them. After reinstalling the outer sheave (get it tight) run for a while and recheck torque on the nut (get it tight again) or you'll be sorry.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 5:30pm
John, If I rember correctly it is an o-ring.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2010 at 11:19am
I was finally combining my corn yesterday.  (Long story).  Anyway, the ground drive variable speed unit is leaking oil like crazy, and lubing the chains on the left side - along with the belts.  I can't find anything in my books about how that unit is put togather or how to disassemble it.  I need to pull the outer pulley with a 2 arm puller but beyond that I haven't a clue.  Perhaps it will be self explanatory.  Is the seal an o ring or something more exotic?  Any advice is always appreciated.  It was 80 degrees yesterday but snowing today so combining may be a couple days off.
This page was generated in 0.077 seconds.
