Later d17 saved from fence row
 Post Reply Post Reply Page  <1 345
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 41 minutes ago at 9:57am
M & W were 7.5 to 1 compression with a 4 1/8" bore. Don't get confused here. It was two things: bore and compression. Raising a 4 inch bore from 7.25 to 7.5 to 1 compression would indeed be a minimal increase in HP.  WD45's can use D-17 pistons and sleeves and just like M & W's give the crankshaft a real workout if it is a plowing/discing tractor. Just the compression increase on a WD45 to 7.25 to 1 would yield 5 to 7 HP I think at 1400 RPM. I'd have to check my engine specs book at home, I'm going from memory.
