Later d17 saved from fence row
 Post Reply Post Reply Page  <123
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2025 at 11:14pm
I got on A and I parts and search that number
(SK156) and they have an overhaul kit for $918 or $131 for the sleeve, piston, and rings per cylinder.
And it says it’s a high compression kit and 4.125” overbore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 2:24pm
Would anyone know of a ring kit for the sp-48 m and w piston?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2025 at 3:40pm
They are available from some of the aftermarket companies.
If I remember correctly, I got a set from Perfect Circle several years ago. You need to measure the size of the rings. All M&W pistons (for the 201/226) are 4.125" (oversize).
evan austin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote evan austin Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2025 at 7:48pm
Steiner lists a piston and sleeve kit P/N ACS3056, 4 1/8" bore, they claim 7.25:1 compression, for $439.99 plus shipping. This is the first time that I have seen the compression ratio listed on one of their kits, maybe it was always there and I didn't notice it before...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2025 at 4:11pm
Think I’m going good used on the two sleeves due to it being decently low houred and the two good sleeves are very good.
Will put rings and O rings on all the sleeves to prevent problems.
Think I will rebuild the head because of a lot of pits in the valves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2025 at 12:02pm
Got the oil pan off today and figured out why it was parked, it had spun a rod bearing…
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:30am
Is the spun rod bearing on one of the good cylinders?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:40am
Yes, it was number 4.
1 and 4 has good sleeves but 2 and 3 sleeves are junk.
Got all the pistons and sleeves out and the pistons look all good. Even the rings don’t look too bad.
