KW Project |
Post Reply | Page <1 45678 20> |
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29485 |
Another consideration I am having in as much as the neighbor decided to be pushy on not allowing a set off of 8 acres is to build a slab/crawlspace house in that valley and for now make a rental property of it
Would stick in his craw every morning he got up and every evening as watched lights in it |
DMiller
Changed PS input seal this morning as telephone company worked bad connection on our service, then came the call Fedex will call me just prior to meet the truck down in town tomorrow and can receive the engine kit been awaiting.
tadams(OH)
Orange Level Access Joined: 17 Sep 2009 Location: Jeromesville, O Points: 9638 |
that mean you could hear it running next week
DMiller
That would be
No Turbo Kit from dual to single and full set exch injectors will HAVE to be another months purchase Get done with what I have and sit awhile!! 250lbs of cyl kits gaskets and fasteners spreads out pretty far |
DMiller
Pics
DMiller
New seats, seat belts, floor mat all awaiting install
Will need do sleeper boot first before seating goes in |
Orange Level Access Joined: 11 Sep 2009 Location: illinois Points: 77710 |
Thats quite a project !! ..... and $$ ...
DMiller
Brand New Iphone 12 pics, was having problems downloading.
Iphone 6 died day before yesterday, had to perform a Hard Reset Reload and was not certain how long would stay usable. Edited by DMiller - 06 Feb 2021 at 3:57pm |
DMiller
MAY end up having to put the old machine BACK to work when complete just to afford fuel.
tadams(OH)
Yes understand that the way the prices have been jumping up
DMiller
Damned Shameless machine!! Besides the snow and now expected 4-12" MORE of the stuff been bitter cold here. Unheated shop side slid below freezing, had a leftover partial cup of water was using for sanding froze sitting on a front tire. Fluorescent lights not liking it where are about half level lighting even left on for a time. Either gonna have to break down and set up some form of heat or just continue to lay low and await a thaw. Not much getting done but scheduling.
DMiller
-4 here this morning, 8" snow total but powdery and drifting. NOT been out to shop in two days.
farmboy520
Orange Level Access Joined: 22 Jun 2016 Location: Beason, IL Points: 553 |
Thanks(1)
Hang in there. there will be better days.
On the farm: Agco Allis 9695, 7060, 7010, R66, Farmall H, and Farmall F20 (Great Grandpa's)
DMiller
Weather just starts to change better and TADA, furnace(HP) Dies, service call by shop that installed it, NEVER seen what is doing and had to go back for test equipment. Gets back meter will not connect to this unit as Pre data stream capable, house is down to 60F. Reaches in to check for any manual resets on Pressure switches and wire falls away from connector, broken but sitting where should have been. PHEW!! a Easy Fix!! Next up right Hearing aid decides to Quit taking a charge, so back to ENT audiologist, only had this set five months so PHONAK agrees to extend warranty to cover as had ended 12/31. ALSO offered a Warranty Extension for TWO Years for same price as would have charged for the two batteries this turn around. At least came out ahead for once.
Took L fuel tank and engine oil pan down to car wash and pressure washed as much as could get Inside and Out. Began sanding corrosion layer of tank so can polish it back up. R Tank still at welders being crack repaired, not on urgent list.
tadams(OH)
Hope you luck with hearing aids mine are 4 years old and am trying to VA to furnish them since I don't get anything else for my time served. I have paid for the last 3 or 4 set I have had.
DMiller
Had these PHONAK devices for a year and half now, they are not so much basic amplifiers but actually target tone levels I have issues with, actually work well when working. Be two weeks should be back, and extended warranty into Feb 2023. Were pricey buggers when got them, my costs close to $4k
Edited by DMiller - 26 Feb 2021 at 6:07pm |
desertjoe
Orange Level Access Joined: 23 Sep 2013 Location: New mexico Points: 13358 |
Well,I been needing hearing aids since,,,,well, when I graduated,,a bunce of us volunteered to the Navy under the Buddy-Buddy plan and all the girlfriends and families had a BIG sendoff in town where they bused us to Albuquerque for Physicals. Well,, after failing the friggin hearing test 3 times,,,the base commander told me they was gonna send me home,,,,This was in Oct of 1965 and the Vietnam War was just getting all out!!!! I guess it was my good fortune,,,,,, I do have a pair of over the ear aids for hunting Elk,,but I don't like em for here ,,,,cause that world out there is too friggin loud,,,!!!!
DMiller
Warmed enough to get some aspects closer to done. Cleaned off floor as will be Thursday before remaining door internals here, measured ONE MORE time Cut floor shifter hole and two furthest internal seat mounting bolt holes installed floor mat, all the under dash components shift boot and pedal assemblies. removed mattress and bunk false floor readying to change the sleeper boot finish cleaning out the sleeper under compartments and determine what small parts are needed here. With boot seal changed can fully install seats and shift impetus back to engine as cluttered floor space will be freed back up with access to areas of workbench back bare. Most of the small tooling can also return to the box.
DMiller
Got cover off, entire top run was sheared. Removed old boot and replaced where will call KW on a replacement cover assembly price or maybe just clean and reinstall this one. New boot was as figured a Bear to install.
tadams(OH)
Looking good, won't be long and the inside will look like new.
DMiller
Well , Better but NOT new!! Thanks TA
DMiller
Getting further but have slowed CONSIDERABLY, as have set myself up success yet again.
Local Contractor has had their OVER Share of grief last several months, Unable to replace retirees, lost one driver to Covid(Passed Away), and just well below any level of MINIMUM for operations day to day. So as a Generous Person I am, called to give condolences and to offer my use IF SHOULD HAPPEN to be able to use a Older Retiree and try to keep it under my SSI limit as to Part Time. So that was several weeks back, Last week he called on a Saturday and asked if what I had stated I really meant or was just being kind, a few moments later I had my start date of Tuesday3/2 !! Rode with a young pup(Nephew to owner) he evaluated my truck operating and functionality with machines then set me on my own on a demolitions job. Hauling busted concrete to one place, raw dirt or loose rock fill another and organics as stumps to yet another. Performed that two days then ran escort duty for the excavator haul from that site to another, next day escort duty to haul a D6H same location both times gave up escort pickup to operator and returned the lowboy to the yard. Hauled quarry stone and lime tailings, hauled #1 mined clay to a service that uses it to produce products for home use of it. Off yesterday, then YET AGAIN volunteered to be second truck for the fella that hauls out of the clay pit for a early start quick half day this MORNING!! Proved myself running a 963B loader Thursday and loaded the trucks first thing this morning, practice. Did still get a little more accomplished on the Beast!! Found a Used Bunk Heat/AC assembly, coming UPS next week(Vander Haag's KCMO) then got boot seal cover Underside cleaned and in then seats set in cab, Right Seat is fully fastened down, awaiting a bulkhead fitting to finish assembly of Left Side. These are the machines I have been running Bucket is Three+ yards heaped, like running a CTL on Steroids!! the spoil pile is the Mined Clay 'Stone'. Been a 'Interesting week' for a Almost Retired Retiree!! |
DMiller
Inner Door panels back on, awaiting some trim screws for the outer inside door panels. Then attacked the Sleeper AC/Heat box, KNEW was a issue just uncertain as to how much as the cores were loose to the floor. Is just a Taste Beyond my Fabricobble capabilities!!! Do have a Clean Used assembly on the way from Vander Haag's in KCMO.
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7981 |
Yer killing me Dave! That machinery just keeps you young! Just keep it part time. Put a sleeper boot in a 89 Int. Not a fun job! KW's looking good!
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
looking good Miller...loving this post!
shameless dude
any of ya'll know if i would put a single semi sleeper on my Dodge dually, if there would be enough room for a short box on after that? i don't know how long the sleeper is on the trucks.
DMiller
This bunk as is typical of the line is a 42" depth, uses a standard extra long single mattress as would buy for a house bed. The old 'Coffin Bunks' were 28" or 30" depending of the make truck.
Edited by DMiller - 08 Mar 2021 at 3:51am |
tadams(OH)
My son has a IH tri axle like the one truck you pictured, yes I would keep it part time as 6 days a week would make for a tired man. The KW is looking good.
JohnColo
Orange Level Joined: 03 Apr 2020 Location: Niwot, CO Points: 1258 |
I do like the looks of those Western Stars.
DMiller
They do drive out nice!
