Knock in transmission of B
gottfriedb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gottfriedb Quote  Post ReplyReply Direct Link To This Post Topic: Knock in transmission of B
    Posted: 20 Feb 2010 at 5:11pm
Now, I know this will sound like a "what kind of dummy are you for not knowing this" kind of thing, but I'm new to tractors and when I learn something new about my little B, it's exciting, so I thought I'd share the experience with my new AC friends:
While moving snow this winter, when I released the clutch, there was a popping noise in the left rear wheel.  I'm thinking that I have a bad gear or something major getting ready to break.  I just knew that the transmission was going to break and I'd have to figure out a way to get my B out of the middle of the road!
Now the good news.  It's warm today so I'm out fiddling with my B.  I notice the left wheel nut appeared to be loose.  So got a large pipe wrench and sure enough, the nut was loose!  Unless I'm extremely unlucky, I think I've fixed the transmission knock! I
My first tractor - 1955 B
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:16pm
 Check the wheel clamps too... I had this happen, in the summer luckily, but the rim came right off the hub... lol!
I know I'm not the first or the last this has happened to... but it won't happen to me again!
Edited by MilesGray (CO/KS) - 20 Feb 2010 at 5:17pm
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Henry se/ks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/ks Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:56pm
I have done  thosands of dollers of  business with Norm. Returned some items that were not correct. Probaly my fault most f time. No problem at all.  Can not  think he would try to beat some  one out of  small item like a junk G. Good man in my oppion.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 5:59pm
I think you have the wrong string here, Henry.
Edited by GBACBFan - 20 Feb 2010 at 6:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote gottfriedb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 6:32pm
Thanks MilesGray for the heads up.  I'll check check the wheel clamps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2010 at 6:41pm
You might wanna keep a keen eye on that wheel for awhile. Some B's have been known to wear either the tapered wheel hub or the tapered shaft or both and torque will not tighten them up completely. A little machine work has been know to help when this happens or lining things up and filling with a good epoxy will fix it. Hope you caught yours in time.
