Just bought a WD
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Topic: Just bought a WD
    Posted: 07 May 2011 at 9:50pm
I just bought a WD today. I think I did ok. It runs, Radiator leaks, wide front, factory Snapcoupler 3 point, good sheet metal except for the fenders that are bent on the rear and a cracked manifold (I think they came that way or happened shortly).
One oddity is the carb. It is an Ensign LP/gas carb.
I paid $990 with the mower. My wife thinks I'm nuts.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 10:11pm
Did it come with 4 rear wheel weights?
Does it have a real factory snap-coupler 3 PH with the centerlink
bracket that clamps on to the rocker arm shaft?
If the answers are yes, you did mighty well!
Please send a few pics of the 3 PH adaptor and center link bracket.
Thanks and congratulations.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 6:46am
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 7:08am
A WD is one handy little tractor, if I could have only one  unit a WD would be real close to the top.
acwdwcman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:12am
i got pretty much the same tractor except had a ms carb and no mower and running great with no problems for $800.
wd with a freeman model 90 trip loader, wd45, 38 unstylled wc, b 10 garden tractor and 2-14 ac trip plow. grandpa has a 56 wd45. wd. allis chalmers snap coupler blade and 3 bottom snap coupler plow
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 10:34am
It only has 1 set of rear weights. One wheel is spun in past the stop so ot looks like it has 2 sets.
It's a factory snap coupler 3 pt. The top link bracket is not factory however. At one time someone welded extra brackets on the lift arms, but later they were cut off.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 4:13pm
Looks like you got a good deal. Congrats!
David Gibson
http://www.darkecountysteam.com
1956 WD45
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 4:26pm
I'd say you did well enough, about any running WD should bring about that money, unless it has also been run over by a tank or something really wrong.
The wife will always think you're nuts, because that is at least 3 maybe 4 very nice dresses to her! :-)
Still in use:
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 4:44pm
Good deal. 3pt adapter cost over $400. Does this WD have a straight gear shift.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 8:53pm
You did good. The radiator should not cost much over $200 or so if you have to get a new one. Take you wife out for a good dinner and then buy her a couple of nice outfits.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acwdwcman Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2011 at 9:29pm
well i know how it feels when i mension anything about buying another tractor she says "you need to get the ones you have all fixed up before you get another."
jeez mom cant a boy dream a little bit? lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 9:50pm
The shift lever appears to have been heated an bent back.
Ed in TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed in TX Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2011 at 10:13pm
I could use a spare Ensign carb for my dual fuel. Let me know if you want to replace it.
This page was generated in 0.127 seconds.
