john deere 2010
rich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich Quote  Post ReplyReply Direct Link To This Post Topic: john deere 2010
    Posted: 23 Jun 2010 at 6:50pm
my friend has a jd 2010 gas tractor, it starts and runs good but it won't rev up or produce any rpms, cleaned the carb and bowl but still won't go. does anybody have any advice.  thanks  rich
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 7:54pm
Does the governor work? Can you move the throttle at the carb and have it change RPM?
Charlie
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2010 at 9:38pm
Check the carburetor fuel inlet adapter, it usually has a screen and that eventually plugs with varnish to drastically limit fuel flow.
Gerald J.
rich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rich Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 9:41am
The carb and inlet is clean and no it won't rev up using the throttle on the carb was hoping it was something other than the governor thanks. Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2010 at 10:41am
plugged main jet in carburetor? birds nest in air intake? mud dauber build up in intake manifold? Opening the throttle on the carburetor should affect engine speed. Broken throttle plate shaft?
Gerald J.
