Jacobsen mower?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: Jacobsen mower?
    Posted: 30 May 2024 at 10:47pm
What makes a zero turn mower want to whine-chatter sound when first moving full pedal either direction? Could it have air in the hydros? How do you get it out? Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 4:18am
Indicates cavitation at the hydro pump, check oil level, filter, hoses...Wink
Codger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 6:59am
What model and serial number Jacobson? Ransomes/Jacobson use many hydrostatic drive vendors.
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 3:45pm
It is a Jacobsen 445g Turfcat. I think mid 90's about 1000 hrs. Has separate pump for  hydro and engine driven off crank for blades. Thanks, Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 3:59pm
Either "Tough Torque", or a "Hydreco" hydrostatic drive pump from the sounds of it.
That's All Folks!
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 5:02pm
Does the chattering go away after a short time?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Codger Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 8:09pm
Need serial number to drill down for correct machine. 2WD, or 4WD? Ford gasoline engine?
That's All Folks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 10:14pm
2wd with Ford engine.Thanks, Tracy
This page was generated in 0.227 seconds.
