Jacking up a Model B front end |
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1055 |
Topic: Jacking up a Model B front endPosted: 13 Aug 2017 at 9:12am |
The bearings are right in there also. Will likely come out when you pull the wheel. Good time to check them and re-pack. discovered a bad one when I changed tires
D17 Series 1
Allis B- 1939 Allis B- 1945 |
1939Dodge
Posted: 13 Aug 2017 at 6:40am |
Same here. As a matter of fact, I just made a tool to buck a replacement rivet, one is missing.
Maybe next weekend. Thanks! |
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 12 Aug 2017 at 8:32pm |
1939 dodge, my '39B doesn't have lug nuts as the hubs are riveted, so the center cap and nut that holds the bearing must be removed to get tire and wheel off. Just mentioning as a thought.. Tim
1939Dodge
Posted: 12 Aug 2017 at 8:20pm |
Gary, thank you for the opportunity for me to boost your ego. Feel better now?
Gary
Joined: 13 Sep 2009 Location: Peterborough,On Points: 5911 |
Posted: 12 Aug 2017 at 4:44pm |
Have you got somebody lined up to take the wheel off for you when you do eventually get it jacked up ? Gary |
1939Dodge
Posted: 12 Aug 2017 at 1:53pm |
Thanks!
I haven't doped it out but will have to find a place to Jack AND a place to set the jack stands. Two places. |
Gerald J.
Posted: 12 Aug 2017 at 9:28am |
All that the shop manual I have on line says is jack the front up and support it securely when working on front wheels. I'd say jack on the frame not the oil pan. Support it with blocks or jack stands. http://www.geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
The military B manual might be more specific. I haven't looked. http://www.geraldj.networkiowa.com/Trees/BMilitary.pdf Gerald J. |
1939Dodge
Posted: 12 Aug 2017 at 7:17am |
Thanks, I may have to buy a taller jack stand. I could lift it in the garage, but daughter has a new car in that bay, and you can imagine what dissent moving her new car for an old tractor would cause....
Brian S(NY)
Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3383 |
Posted: 11 Aug 2017 at 7:32pm |
I somtimes use my engine hoist on the B and lift the whole front of the tractor, but we also have an extra cross bar bolted across the wishbone just above the hubs that makes a good jacking point also. HTH's
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55293 |
Posted: 11 Aug 2017 at 6:16pm |
Jack where convenient, the tractor is built tough enough, to take it anywhere...
Just be sure to put it in gear, and chock it, both ways, and ude a jack stand, when you are done jacking...
1939Dodge
Posted: 11 Aug 2017 at 8:12am |
Thanks Tim!
I appreciate the REAL help! I plan on cribbing high enough to make the floor jack reach. |
TMiller/NC
Posted: 10 Aug 2017 at 9:16pm |
I usually just place the jack in the center, it lifts both front wheels, but is not a concern.. in your case the left side will be heavier when right tire is removed and might tilt to that side...Be sure to block or use jack stand to prevent falling. Be safe, Tim
1939Dodge
Posted: 10 Aug 2017 at 9:03pm |
Thanks for the help Gary.
Right side. Do l block up under the wishbone, or Jack it from the tie Rod area? |
Gary
Posted: 09 Aug 2017 at 4:02pm |
Have you got a wife or girlfriend you could ask ? Gary |
Stan R
Posted: 09 Aug 2017 at 3:09pm |
Which side- left or right?
1939Dodge
Posted: 09 Aug 2017 at 2:15pm |
I have to pull a front wheel on my 1939 B. Where do I place the Jack and blocking?
