Its only Nuts and Bolts in memory of Don(MO)
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Topic: Its only Nuts and Bolts in memory of Don(MO)
    Posted: 08 Mar 2020 at 10:02am
Folks,
 Guess I am missing those phone calls with Don Bradley. So I wrote a little piece and am going to try to attach it here.
It’s only nuts and bolts!
2-22-2020
The WD45 was on its knees at the auction block
One more bid and it was ours.
As I proudly loaded it my first call was to Don for a talk
He congratulated me and we reviewed the weather
We grew as friends speaking often of tractors and life
So far apart so close together
I did not know the future of this old orange tractor was in Don’s hands
 He was going to refurb this tractor a thousand miles from his shop
After some time I called him and said the 45 is sick
 the oil looked light gray and way too thick.
He said set down we need to talk
And we did for many hours and many times after that
He would say,  now you write this down
I’m going to give you the list
Don’t stray from this path it is the way we will fix it
I found the cracks in the block just as he said
You can fix this tractor or “knock it in the head”
I being older and more stubborn felt it needed to be saved
I mean when would another worn out 45 come our way
I didnt know we had no time to find another
 We dove into this one and he helped on each move
 I had the expert on the other end of the phone
He was happy I found a good block when I called him at home
Don said set down there are more things and details to know
Those mains need line honed. The crank may be bad
Lets do this right and you will be happy you have
I have a way to fix the thrust, not many will listen
Remember he noted
 Its only nuts and bolts
you can do this I’ll help, call me any time
 I ask if this detail really mattered.
He noted that you could look the other way on that one.
But dont mess up on this new list of things to check
On the setting the sleeves he was firm and noted
Get this part right, it is very important.
It took hours to do but he wanted it right
How was I going to take it apart and put it together?
He said not to worry he was just a phone call away.
His recommendations were noted and written on scraps
 We discussed every point
The valve lash, the head torque, the seals and the fits
Get the book out and study it, then call with questions he quipped
Things that were broken and parts need to be fixed
I was tired and sore and it took a long time
Dust and dirt in my eyes and hands covered in grime
How was he going to help me from so many miles away?
He did it one phone call and talk at a time.
The tractor became a reason to call, but not all
Our kids, our grandkids were discussed often too
The calls were about family the weather and the farms
Lot of encouragement came from the other end of the line
Before he hung up he would note
Hey dont forget, on that tractor
Given the reins he would have made this into a hopped up machine
 but he could hear in my voice
 I wanted this one box stock with that Persian Orange gleam
He knew every move I was making and quietly gently guided me through
Don followed me on the forum, watching for errors,
I would get a phone call from the master critiquing my work
Some improvements to make some mistakes he let me make
It will be a strong tractor
 you’ll be proud of the work you have done
Constant reassurance would be heard on the phone
We built it all stock his knowledge I absorbed
He was so proud, maybe prouder than me.
When that 45 came to life on the very first turns
I called Don and he just beamed over the phone
Don’t say you can’t do it. You wrenched on the whole thing
It was really his tractor, as I look back with a smile
The last time we talked we discussed the orange 45
Setting the governor was discussed for a while
 He said I have to go,
Little did I know it would be our last call
Very pleased to have been able to help Don
refurbish “our” WD45 tractor
Remember
In Memory of Don Bradley
Chris Casbohm
Edited by Sugarmaker - 08 Mar 2020 at 10:10am
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 10:38am
 WOW,,,Chris,,,what a great tribute for your friend. So sorry for your loss and may PEACE be with you. Those are the Special ones in our lives,,,,,,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 12:05pm
Great tribute Chris
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 1:00pm
Amen!, lot of thoughts there!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 1:08pm
WOW ! again, Amazing poem . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 1:19pm
That's a great tribute- and should have a place with the Allis Chalmers Club of Mo,,,,,
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2020 at 11:27pm
Thanks for posting that, Chris.  Sometimes we don't know what we have until it's lost.
Allis Express participant
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 2:13pm
Thanks for posting Chris
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2020 at 4:49pm
Anybody know what he was ill with? And how old? It's a shame he had to go.      Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2020 at 1:48pm
Don was a young 62 and I can understand why he had congestive heart failure.  His heart was SO BIG,,,,,I too spent hours on the phone with him.  He ALWAYS had time for others and "there is no such thing as a dumb question on these tractors".
You did really good on that Chris.  I'm sure he's proud and smiling down on all of us.
I haven't seen anything of Bobby on here?  Anybody heard from him?
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 10:08pm
I was actually looking for Bobby. Lost my dad a month ago and was thinking about him. I talked to Don a hand full of times trying to troubleshoot a few things. One was a troublesome AC on an L2. Don’t remember the other but we talked for quite a while both times. I almost went to his plow day but got busy on the farm. Now I wish I had made time. Life is too short and precious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2020 at 10:28pm
thanks for posting this! i didn't know him, but sure would have wanted to.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 8:04pm
I spoke to him once for a few minutes. Was a wealth of info. I'm sure he is being missed by everyone that knew him.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 11:11pm
Dittos Tom...  " Was a wealth of info. I'm sure he is being missed by everyone that knew him"
 It was interesting to read what he had to say in his replies to other people's troubles.
Sure wanted to go to the show where he was demonstrating the right way to install pan gaskets but had to suffice for the video.
Talked to him a couple times, once was in 2018 at Hutch.
 Was thinking about asking him if he desired to do anther 45 diesel engine but  he departed from us way to soon.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 8:52pm
Just a comment Don made to me many times! He told me to stay away from those old 45D's. He said if I bought one and it needed rebuilt, to have a extra 5 grand in my wallet to do it right! I am sure he was correct. I have skirted around those when I had a chance at them.
I had plans to stop at Don's this June when we we going to Denver. The trip didnt happen. Would enjoy talking with Bobby. Don spoke so highly of him and was so proud that Bobby was getting interested in these old tractors too!
Here is the WD45 he helped me with.
Edited by Sugarmaker - 16 Jul 2020 at 8:52pm
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 9:12pm
Excellent writing, Chris!  A great tribute to Don.  I had the privilege of taking a class that Don & son Bobby taught.  "Why Won't My Tractor Start?"  Dan Hauter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 9:27pm
Bobby Bradley can be reached at 660-909-5406.  I last saw him at the Missouri
Allis-Chalmers Club's swap meet at Lathrop, MO in early March.  Bobby has his own health issues, lost his dad, & has the estate to settle.  That's likely why we haven't heard much from him.  Bobby co-taught the class with his dad and both of them did a great job!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2020 at 6:14am
Dan,
 Thanks!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 10:20am
Chris,  You will have those thought for your life time.  Those are the ones that keep us going during our darkest hours.  Cherish!  On another note, "DON" would look good stenciled on that tractor somewhere. I.M.H.O.
Regards
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 11:19am
Just thought I'd add this:  It was obvious during the class that Don was proud of Bobby and thoroughly enjoyed having Bobby as his co-teacher.  Don & Bobby worked well together.  Dan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2020 at 5:28pm
Very nice Chris!
