ISO Power Steering Line for D17 series IV
thester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thester Quote  Post ReplyReply Direct Link To This Post Topic: ISO Power Steering Line for D17 series IV
    Posted: 11 Aug 2022 at 7:32pm
Looking for power steering line for D17 Series IV. If sitting on tractor it is the small line on the left side. Runs from pump to left side of reservoir on from of tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2022 at 9:28pm
I'm going to assume a gas tractor ?? Diesel lines are all different. Lines from a series 3 are the same as a series 4.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thester Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2022 at 5:49am
Yes Sir. You are correct and thank you for the response. If I were to try and build a line myself. Would you know the size of the line # 5 and fittings?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2022 at 6:33am
That's the pressure line, so it must be good enough for 1600 psi. If you don't have your old one for a pattern, that will be a challenge to make one identical. The pump hole is "inverted flare" which is kind of odd. The bottom is too, but you could make it into JIC connections.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thester Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2022 at 7:18am
I have the old one for a pattern and I should be able to reuse the fittings. I’m just unsure the exact size of the steel line. Once I have formed the line I should be able to have a high pressure hose attached.
Albert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2022 at 7:53pm
I am  sure it is a 5/8 line but you better measure it. A 5/8 open end quality wrench will tell you.
Albert
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2022 at 6:27am
If you have the line; Send it to Inline Tube to have a replacement one copied from it.
VaAllis1990 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VaAllis1990 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2022 at 7:20pm
Agco still sells it
Post Options Post Options   Thanks (0) Thanks(0)   Quote Albert Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2022 at 7:35pm
70237389 NLA from AGCO
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2022 at 5:12pm
If you have the old one, a local hydraulic shop can make one to match it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thester Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2022 at 6:51am
Thanks for all the responses. Found the line from a gentlemen in PA via EBay.
