Is this a 230 or 262 engine? |
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34626 |
Topic: Is this a 230 or 262 engine?Posted: 30 Apr 2023 at 11:22am |
Brought home a D17 with a 6 cylinder engine in it. Auctioneer said it was a D19 as what the seller said it was...then said it maybe was just the engine that was a D19. But it didn't look right for a D19 engine with the water volute coming off the side of the head. Thought all D19 engines were of the more modern design going straight forward. Well, thought maybe this engine was a combine engine but the C series combine engine I have is of the similar design of the D19. notice the side discharge on the head. ![]() Notice the manifold, this is centered for carb and has extra heat to the intake side from the exhaust side... D19 and the 230 on the A allis combine have the carb more towards the front of the engine. So was this an industrial engine? ![]() No ID plate on the engine just the cast number of 45 with stamped in marks after it.... then under the rod is cast a number of 27 and the cast in date looks like 1-27-59 ![]() Looking at the cast number of 45, it almost looks like a 0 was ground off after it. Big question is, how can I tell that this is a 230 cube engine or a 262 engine? and was it a low grade fuel burner (low compression engine) or a regular grade burner despite the design of the manifold. thanks.
Edited by JC-WI - 30 Apr 2023 at 12:12pm |
Posted: 30 Apr 2023 at 11:39am |
I'm gonna say a 230 engine because of the manifold, water pump/cylinder head design and the 1959 casting date.
Edited by DrAllis - 30 Apr 2023 at 11:40am |
JC-WI
Posted: 30 Apr 2023 at 12:19pm |
Doc, I had thought the same thing, but the early D17 diesel was
262 of the nearly same design. and the D19 came several years later
with the newer design and the D17 diesels got the newer designed engines
as well. And as far as I know, the 230 got left behind. If it is a 230, wonder how the HP and fuel consumption will compare between it and the 226?
Posted: 30 Apr 2023 at 12:37pm |
The G-230 and G-262 were used in the A and C combines and the D-19 tractor. The D-19 never had that water pump or manifold design. If they made a G-262 before 1961 (D-19 time frame) I am unaware of it.
JC-WI
Posted: 30 Apr 2023 at 3:03pm |
Went and looked in an old The Tractor Field Book with power equipment specifications, published by Farm Implement News Co., Chicago 1956. They had a section under 'Specifications of Multi-Cylinder Commercial Engines'. Each company was listed with the gas models and then listed with the diesel models. Under Buda, they listed 11 models of Gasoline and 11 models of Diesels.... I see they listed the 6B-230 and a 6B-273, but no 6B-262. I also see in the Diesel section they listed a 6 DA-230 which was a close copy to what was used in the WD45 and a 6 DA-273 that Cockshuts used but no 6-DA-262 engine . So AC must have developed the Diesel 262 for the D17 and then the gas version and turboed diesel262 for the D19. Thanks ![]() |
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1125 |
Posted: 30 Apr 2023 at 3:38pm |
What about a dsl that got a gas head installed? Air cleaner looks cobbled on and dsl batt box?
Posted: 30 Apr 2023 at 3:53pm |
What's the chassis s/n ? .....17-XXXXX or 19- XXXXX. Power steering pump definately D-19 or series 3/4 D-17. Air cleaner is homemade in design and location. Also, the BD-273 is a bored block...no wet sleeves. The 262 series was an Allis-Chalmers created engine with wet sleeves that sank over time.
Edited by DrAllis - 30 Apr 2023 at 3:56pm |
Posted: 30 Apr 2023 at 7:22pm |
Looks to me like the engine s/n is 111570 ?? which could very well be. The D-17 parts book says that old water pump mount design was prior to engine s/n 119938.
JC-WI
Posted: 30 Apr 2023 at 7:44pm |
The air cleaner looks like something off a D14? or a power unit? The intake is about the size of the WD's intake pipe. The location of was determined by the previous installer, and the hood still has the front hole. Power steering pump arrangement does look like that of a D19 Manifolds are certainly different than from an A Gleaner 230 engine. ![]() SN is D17 7640D ... Tractor 1958, block first month of 1959. Close in age. lol Was
looking at the chart and see the 230 could produce 73HP at 3200 rpms
and 164 ft pounds at a thousand rpm, with 6-1 comp. ratio, just think
what it could have done at 8-1. |
Posted: 30 Apr 2023 at 8:15pm |
Think of it this way: A-C hadn't used this gasoline "B"-series engine yet in farm tractors, as the D-19 was first in 1961. I think the carb/manifold design mimics the Buda engines used in Cockshutt tractors. Same can be said for the water pump/cylinder head design. In 1961, the engines design features change and the old B-230 series gas engine now becomes the G-230 and it's bigger brother the G-262, both with new designs in the manifold and water pump components. They are now Allis-Chalmers engines, not Buda.
JC-WI
Posted: 30 Apr 2023 at 11:13pm |
Dr., that seems to be looking like how it played out. And to think Allis bought Buda out in November of 1953. Buda had been hard at it to try and get their engines into all parts of the industry and into the trucking industry too... after Allis purchased them, that effort waned, as I have read. Been an interesting thread looking into the Buda engine in this tractor... tho it might have been better if it had the 262 in it instead. Now to see if the 230 will start and run... if it's junk, I will put the 230 from the combine in it, that engine ran really good. Thanks fellas for your thoughts.
Posted: 01 May 2023 at 6:33am |
The picture of the engine painted grey in color, I would call a Gleaner model "A-2", not a straight model "A". So, the Gleaner model A series combine was built from 1951 thru 1967. Not sure when the A-2 came out, but I'd guess 1961 or later, kind of following the D-19 engine time line. With that in mind, you'd have ten years of engines in older model A's that very well could have had that old Buda style manifold with centered carburetor and water pump hanging from the cylinder head AND possibly painted orange ??
JC-WI
Posted: 01 May 2023 at 1:09pm |
Just to correlate the time line, I should go and find the data plate on the combine. Didn't stop to think about it, but yea, over the years there were gray engines and there were orange engines on those Gleaners.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 01 May 2023 at 4:56pm |
Definitely not a D14 air cleaner - too big. Tractor was most likely a diesel that someone replaced with a gas engine and moved some components around - including the air cleaner.
JC-WI
Posted: 01 May 2023 at 11:57pm |
D Series4,
This tractor was a D17 Diesel when it left the factory. Some where along the way it got a heart transplant, with the Buda 230 cu engine of the older style. The air cleaner looks like it was bolted to a flat surface before it got welded to the battery tray...Just can't fathom the size of the intake pipe being small in diameter, being sufficient for this engine. I was wondering where this Buda engine really came from which prolly was a Gleaner Combine, but maybe it was in some other application like on a conveyor or forklift or some other job. Don't know. Pulled some plugs today, and the engine turned over nice and smooth. Took out no. 5 and 6 first and they looked clean.. no. 1 had something inside the cylinder that was kinda yellow gunk, 2 and 4 were gunky and carboned and no. 3 had crap across the electrode... and funnier part is, these were long reach plugs in a short thread hole. At least the pistons didn't hit the ends of the plugs. Thinking it may have some oil control rings stuck or broke... I am wondering what I should soak those cylinders with to dissolve the possible carbon that is sticking the rings. Need to work the ignition side and put some battery cables on and a temporary gas supply and give it a whirl and see what all comes flying outof the exhaust. Hope it runs as good as when turning it by hand... smooth. Thanks.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11858 |
Posted: 02 May 2023 at 12:08am |
Curious if it has the combine (limiting-speed) governor, or the tractor (variable-speed) governor?
Posted: 02 May 2023 at 5:44am |
Tractor type governor is what I see,
JC-WI
Posted: 02 May 2023 at 9:48am |
Tramway, as the doc said, it is of the tractor variable speed governor. There is another D17 in our area that was changed over to the 262 gas motor from a combine and they had to hunt down a governor assembly for that one. That got changed in about 1979 and still in use, but the owner says it is really hard on gas. He uses it for cutting and baling hay but has a smaller tractor to use for raking the hay.
JC-WI
Posted: 02 May 2023 at 11:12pm |
Doc, I was looking at the 1956 book again, in there it was listing the Allis Chalmers combines... 100 with the 226 engine, Gleaner T-2, & T-3 having Ford JD 172 4-3.9x3.6, Gleaner A with a Hercules 6-3 7/16" x 4 1/4", and listed same engine for the R and B. according to that Baldwin was putting them in instead of the buda?
Now the bad news on the D17dG , Opened the crankcase drain plug a little bit and had about pint and a half of antifreeze drain out. Guess it isn't as good as I had hoped for. Going to still start it and see what the rest of the tractor is like, like clutches work, gear jumper or not, 2spd work or jumps out... it seems to far forward and backwards to engage. imo. And see if pto & hydraulics, ps., and brakes work. |
Posted: 03 May 2023 at 10:46am |
That Hercules sounds like the same bore and stroke as the Buda 230. Anyway, I can't imagine after 1953(or so) that A-C would have used anything but what they owned and built. Been too long ago to find much out, but I could see 1951 thru 1953 something other than Buda. But after that, Buda or A-C/Buda. Same thing in reverse happened to the F and G combines. Had Allis engines and then went to GM Industrial.
Brendan (AB)
Posted: 07 May 2023 at 11:22pm |
That engine looks exactly like the 230 in our old Gleaner A combine. I don't know exactly what year it is, but it is an A, not an A2. Here are a couple of pictures for comparison.
![]() ![]() We also have an older Gleaner A parts combine that has the Hercules engine. The Hercules is a flat head engine, so completely different than the Allis/Buda engines. It's interesting that they have the same bore and stroke, I never knew that!
Posted: 08 May 2023 at 6:01am |
The governor on that combine engine truly has a "combine" governor, so the tractor engine we are talking about has sometime been changed or it never came from a combine. The S/N on that combine should be on a plate on the left side of the body under the ladder/battery area.
Brendan (AB)
Posted: 08 May 2023 at 11:29pm |
I did some looking and found the combine serial numbers. The A with the 230 was built in 1960, while the A with the Hercules was built in 1955. Just for interest, I did some reading in Norm Swinford's book and he wrote that Allis switched from Hercules engines to the 230 sometime in 1957.
JC-WI
Posted: 09 May 2023 at 11:01am |
Brendan, your 230 engine looks really clean. I went and checked the gray engine A Gleaner I have and serial number is A-40361. Can't find any serial number breakdown of years for the Gleaners. Just for note on the specs of the Buda / Herc engines used , the book I have said the Herc used was the 3 7/16th x 4 1/4th with valve in block while the later Buda engines used in the Gleaners were the 3 7/16th x 4 1/8th ". The QXLD engine was 7 cubes larger than the Buda used. Hercules did have a 230 engine also, a QXD. Difference between them was the QXD had the 3 7/16x4 1/8 that was 78.4hp @3200 with max torque of 167@1500 ... while the QXLD had 92hp at 3200rpm 190@1400rpm As for this D17 with the earlier Buda engine, I have had it started and it runs. But the throttle linkage seems really off to the throttle lever, first quarter of quadrant it seems like it is full throttle and any farther that engine seems like it has no stop to the upper rpm's. Governor linkage looks like it has many kinks and a weld in it, so... somebody has played with it. I don't like over speeding engines, so need to put some kind of a tach on it to see what it really is running. Tires on the tractor are 14.9x28 and are full of fluid and they appear to have been leaking for a long time. Replaced the valve core on the one side and the fluid was over the top of that... sprayed out some from core hole, wasn't bad. Then had to replace other core only to find the core corroded and had to remove the insert to replace. That was not the screw into the tube kind, but the style that is held by the threaded collar which was also rotten and broke when trying to loosen it. Once that broke, tried to keep stem in tube while trying to remove collar and... stem blew out and a stream of chloride insude. Shoved new stem in and was able to crack the old collar and peel it off and then threaded the new collar on. Then took a shower to get rid of all the chloride off of me. That makes 6 tires that I have worked on in two years that have had fluid over the top of the valve stems. These two I didn't take time to remove the excess fluid from them. From the previous 4 tires (set of 18.4x34 and a set of 18.4x28), I removed about 60 gallons. Is that the norm for the tire shops to over-fill tires? Have to see what a D19 book says about the governor and see about maybe setting a limit on top end rpm.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8982 |
Posted: 09 May 2023 at 2:19pm |
My opinion...a real tire shop would not fill over stem.
Brendan (AB)
Posted: 09 May 2023 at 11:59pm |
JC,
As best as I can tell, your A2 combine would be a 1967 (last year for the A). There is a chart in Norm Swinford's book that lists serial numbers and years for the Gleaner combines, that's where I'm finding this information. Hope this helps, good luck with your tractor!
