Is a B and a C and a CE engine |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2580 |
Topic: Is a B and a C and a CE enginePosted: 09 Dec 2023 at 2:13pm |
Same engine? Y’all have a safe weekend. Thanks DANA
Blue Skies and Tail Winds
Dana |
dfwallis
Posted: 09 Dec 2023 at 2:36pm |
Depends on the year (SN). B had a 113CI Waukesha, then a 116CI BE, then a 125.2CI CE C had a 125.2CI CE CA had a 125.2CI CE with slightly higher compression ratio.
Edited by dfwallis - 09 Dec 2023 at 2:42pm |
Joined: 11 Sep 2009 Location: illinois Points: 88653 |
Posted: 09 Dec 2023 at 4:22pm |
The WAK engine was only used in the first 97 B tractor or so.. about 1937... Then for 3-4 years the B had a 116 inch BE motor... Sometime late 1940 the model C came out and the motor was changed to a CE 125 inch and used in BOTH the B and C till 1950.... Then the C was replaced with the CA tractor and continued to use the CE engine till 1958 or so..
There were a few "changes" in the compression ratio over the years, but the same basic engine was used ...... and you can put new pistons and liners in a BE engine to get to the CE engine specs.
Edited by steve(ill) - 09 Dec 2023 at 4:29pm |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12027 |
Posted: 09 Dec 2023 at 5:02pm |
Don't forget the RC. That had a B/C engine in it as well. I think that only had the 125 version if I remember correctly.... Steve@B&B
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1285 |
Posted: 09 Dec 2023 at 5:33pm |
Identified by the CR prefix on the engine serial no. |
captaindana
Posted: 09 Dec 2023 at 7:46pm |
Thanks y’all
Dana |
Posted: 10 Dec 2023 at 8:03am |
If ya ever went to the County Fair from 1950 - 2000 you probably saw one of them engines running the Ferris Wheel or other Ride.... Dont see as many these days.
Steve in NJ
Posted: 11 Dec 2023 at 8:58am |
Yup! Yer' right Nathan. Forgot bout' that. My RC engine has the "CR" code on it....
wjohn
Posted: 11 Dec 2023 at 6:08pm |
Now hang on... I always thought the RC engine had an "R" prefix and "CR" was from a power unit. Is that wrong?
Edited by wjohn - 11 Dec 2023 at 6:08pm |
GreenOrange
Joined: 11 Sep 2009 Location: Wisconsin Points: 851 |
Posted: 14 Dec 2023 at 2:15pm |
RCs had an “R” prefix. There were also “R” prefix power units and then the CR prefix followed those. RC was out of production by then.
No idea why they weren’t “RE” to follow the same labeling convention. Edited by GreenOrange - 14 Dec 2023 at 2:15pm |
dfwallis
Posted: 14 Dec 2023 at 3:30pm |
Shows RC as distillate only low compression engine rather than gas.
