intercooler for d21
Toscani NE SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani NE SD Quote  Post ReplyReply Direct Link To This Post Topic: intercooler for d21
    Posted: 08 Mar 2015 at 7:47pm
is it possible to put a intercooler off a 7060 on to a d21?the 21 has a 220 engine, whats all involved that I need to know?
Peterson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peterson Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2015 at 7:56pm
Yes it is, but you must run the newer style water pump to hook it up correctly. But then the water inlet for the pump is on the opposite side of the radiator.
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 2:20pm
The AC intercoolers as Harrison fixed for pulling I saw either used a straight thru flow as he used the rear cap on the front and drilled/tapped for a 3/4 pipe using the pump to flow through front to back, or the same set up using a front divided cap with 2 1/2 " fittings tapped in left side and right side allowing the water to flow front to back as it does stock. I would vote straight thru....
Many an intercooler on the AC's were put in 90 degrees off thus reducing the cooling by a bunch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:34pm
I always assumed the OEM way (front to back on one half and then turn around at the rear and go back forward) was an effort to keep the air temp delivery to the intake ports close together front to rear, instead of being cooler on the front and warmer at the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2015 at 9:36pm
Yes, I too have seen 426 intercooler cores rotated incorrectly allowing air to flow right by the core.
This page was generated in 0.949 seconds.
