Identify This Guage?
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Identify This Guage?
    Posted: 01 Jan 2011 at 7:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 7:36pm
Well I can't seem to bring the picture up.  I'll keep trying.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 7:39pm
When I try to get the picture from photobucket, I keep getting a message about global settings.  Anyone know what the deal is?
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 7:49pm
   This one ?  :
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 7:52pm
It needs to be a better picture. I got to your photobucket album but the picture isn't good enough to blow up. It could be a steam pressure gauge??  If the picture was better before uploading to Photobucket, send it to my email and I will post it.  Charlie 1954wd45@gmail.com
Edited by CTuckerNWIL - 01 Jan 2011 at 7:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:03pm
that is the picture.  how did you do that?
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:11pm
Just a shot in the dark, would definitely be able to tell with a larger picture, but it appears to be a Steam Pressure Gauge from a Factory boiler or piece of machinery.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:21pm
Why it's an Exhaust gauge?? Shows vacuum and pressure.And it's about 6 lbs off. LOL
Edited by CTuckerNWIL - 01 Jan 2011 at 8:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:29pm
It measures the vacuum and pressure of something? Maybe a turbine of some sort? Allis did make lots of them...
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:30pm
Im betting it was on something Steam.....
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 8:31pm
it looks to be in good condition other than the 6 pounds off factor.
J D (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J D (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 9:39pm
I think the gauge units must be   "Hg, (inches Mercury)
It would be hard to get 30 psi vacuum on earth where atmosphere is about 14.5 psi
What I cant figure out is how you would get negetive pressure on exhaust ?
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 9:44pm
Likely messuring water column pressure. Very small increments compared to PSI.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 11:58pm
Probably pressure or vacuum at the steam exhaust of a steam engine or turbine into a steam condenser. A steam condenser tends to pull a vacuum on the engine or turbine when its working right condensing steam and that's more pressure drop across the engine or turbine to extract more hp from that machine.
You want to see the power of condensing steam, take a metal can with screw on cap, like a solvent can, put in about 1/8th can of water, put it on a stove or hot plate and bring that water to a boil. Take it off the heat, screw the cap on tight and let it cool. You'll need oven mittens to do that safely. Let it cool. The condensation will pull a vacuum to the point the can will be crushed down to the volume of the water it started with.
Gerald J.
This page was generated in 0.104 seconds.
