Identification help please
kaddiddle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kaddiddle Quote  Post ReplyReply Direct Link To This Post Topic: Identification help please
    Posted: 04 Dec 2013 at 12:17pm
New to this site so thanks in advance. Father-in-law and myself bought a us a toy for around the farm and we need a little help. Bought this AC backhoe loader at the auction and was told it is a 715 with a ford backhoe. How do I know if it is a B,D or whatever? Where do I look for the model number on the chassis? It runs good and the hydraulics stated to get sluggish so we drained the fluid and pulled the filter. The old filter looked to be modified and was not incased in metal like todays hydraulic filters. I found the adobe file of the 715 on line but we are not so sure everything matches. What type of hydraulic fluid is recommended for this machine?   I have attached pictures if it will help. Picture file is too big. any suggestions?
Edited by kaddiddle - 04 Dec 2013 at 12:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2013 at 1:37pm
When you get the pic uploaded, click the preview button in the file manager. A width and height size will show in the little boxes. Divide each by the same number so you get 800 or less for width.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2013 at 8:51pm
That is a 715 'B' series tractor/loader/ backhoe. Built in the early 80's  I've had one for 26 years.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2013 at 9:58pm
Nothing Ford about the hoe - is a 715B - hyd fluid - whatever you want to use - torque converter Type A .
 see upper bucket are is bent - had to press both mine straight .
look for my post on 715B hyd pump brace if it does not have one now . saves the front timing cover/
Post Options Post Options   Thanks (0) Thanks(0)   Quote kaddiddle Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2013 at 7:18am
Thanks for the response, I have review your post and looked yesterday at the pump and housing and it is cracked. Looks like it was like that when we bought it and the seller covered it when he painted the machine. Thanks again for the info. Sure I will be inquiring more as time goes on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2013 at 7:30am
Actually there is a little Ford in this machine. The rear end and rear axles are Ford.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2013 at 11:17am
That front cover can be replaced or once a brace is put on pump , sealed or slowed down with goop of some kind over crack, silicone jb weld, or your favorite
 Yes Ford rear but not the hoe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kaddiddle Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2013 at 3:26pm
Thanks for the reply
This page was generated in 1.594 seconds.
