i600 tune up kit |
Author | ||
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Oct 2023 at 5:49am |
Where’s the best time lace to buy a tuneup kit for my I600?
I assume it’s the same as a D15? I need points, condenser, cap and rotor. Possibly a coil? Will start and run for a few minutes then start sputtering. Very rusty inside the distributor . I cleaned everything up but it still dies out after a little bit. Points look wore out and condenser is very corroded and rusty. |
Sponsored Links | ||
IBWD MIke ![]() Orange Level ![]() ![]() Joined: 08 Apr 2012 Location: Newton Ia. Points: 4107 |
Napa? That's where I get Echlin brand ignition parts.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5244 |
Would be a great time to go with a Pertronix ignition and not t have to worry with finding a good set of points, condenser, or coil. If you do make sure you go with the matching plug wires. For a little more money you will have a better starting and running tractor. My brother switched our D15 over to it and it runs so much better.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7516 |
I would make sure your fuel system is in good shape first - no crud in the tank or carb. Shouldn't need a coil, but I would go with plugs and wires if they look old.
I checked out the fuel system. Pulled the carb drain and let some gas flow. Keeps a steady stream and looks clean. If I let it set a few minutes it starts and runs perfect for a couple minutes then quits. Let it sit and same thing. Change me doesn’t help or change the situation. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88268 |
sounds like a bad condenser... but a coil is also a possibility..
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54298 |
Don't forget the ignition switch easy way to check it is with a hot wire...
Good point |
I’m giving this some serious thought. Dies it still require the old coil? |
If I remember right, pertronix needs a coil with 3 ohm resistance... look it up for sure on their website, I'm sure they have one...
As far as I know the old coil can still be used but when I did my upgrade I went to a matching Pertronix coil.
