I600 hydraulic problems
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: I600 hydraulic problems
    Posted: 02 Jun 2024 at 8:27pm
First, one of the outrigger cylinders is leaking. It has the end cap welded on and the weld is leaking.
How should I go about fixing this?
Second, the Cessna rotary swing cylinder started leaking top and bottom.
Where can I get parts?
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 8:32am
 Hey Thad,,, I went thru similar repairs on the rotary swing cylinder and one of the backhoe's cylinders on my tractor some years ago,,,I went back to try to find my write up but couldn't find it,,,,WTH,,,,???
 There was a gentleman on here that I bought the new seals from for a complete overhaul of that rotary cylinder and his name and address were in my thread,,,(hope he's still around)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 11:43am
Yes hoping
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 3:52pm
I once saw a write up on converting one of these to cylinders. Anybody know anything about that?
Edited by Thad in AR. - 03 Jun 2024 at 6:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2024 at 12:51pm
I found an Agco parts number 837180M92
$736.00
Is there a way to see if this is correct?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 12:27am
The end cap on cylinder seems to be a common problem and clean and weld it up is the solution . On my hoe off my HD4 both cylinder end caps cracked next to barrel of cylinder , I just v ground the joint and welded it up without disassembling cylinder by moving piston to full extend .
 Left some posts on your other post on the Cessna motor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 5:22am
So I don’t have to disassemble the cylinder?
I’ll give this a try.
Thank you Coke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2024 at 11:37am
With cylinder off machine and ports open so any content left in cylinder can gas off , just clean up area and V out part of old weld and carefully lay a bead over area for repair .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2024 at 5:19am
Thank you Coke.
I’ve been using it hard lately . Things are starting to show their age.
I have some work to do for sure.
