I-600 engine choices
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: I-600 engine choices
    Posted: 31 Dec 2018 at 5:47am
I need to know what will swap into my forklift in place of the 160/149. I can do fab work. I have a good 201 and a AD3-152 Perkins also.
Thanks. Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 6:11am
None except D15D without adapter plate.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 9:44am
Mack, do you know of anyone that might have done the 201 swap with the adapter plate. Or maybe the Perkins.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:06am
In order to get that 201 to fit in there you'll spend about as much money/time as to find a donor 160/149.
Can't fix stupid
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:07am
BrianC- Is the 149 or 160 beyond rebuild, or just looking to add a little more HP?
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2018 at 11:32am
A 201/226 is too wide to fit between the side frames. The flywheel is too large and too deep to fit into the bell housing.
This page was generated in 0.050 seconds.
