I 60 backhoe |
fastallis
Joined: 13 Nov 2010 Location: Avilla indiana Points: 172 |
Topic: I 60 backhoePosted: 20 Aug 2013 at 7:14pm |
I just bought a I 60 loader backhoe. It is pretty rough but runs good. It is missing a few things. The hood sides are gone. The pipe from the air cleaner to carb came with it but how does it connect at the cab? Another question? i think the hydraulic pressure relief is turned in to much if you bring a cylinder to the end of it's stroke you will kill the engine. How do you adjust that or is it normal? Thanks for the help?
Dan LaRowe
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55278 |
Posted: 20 Aug 2013 at 8:09pm |
There should be a pressure relief valve, on the valve bank, you will need to see if it is stuck shut, or screwed all the way in. Carb to air cleaner should be just a hose, and hose clamps holding it on.
