hydraulic system flush ??
bacon6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bacon6 Quote  Post ReplyReply Direct Link To This Post Topic: hydraulic system flush ??
    Posted: 23 Feb 2011 at 6:03pm
I have a A C 5015 where the trans/hyd. are 1 system. they are contaminated with water, I've replaced the fluids and filter but still need to flush the system better, is there some kind of flush I can add to the system before draining the fluid again??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 7:19pm
I,ve heard diesel fuel works , add some run it a little , pull the plugs and let it set a day to all drain out , never tried it but I think it would work
Gatordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 8:03pm
The heavy equipment shop i work with uses dexron atf to clean out water contaminated hyd and power shift trans systems
KevinON View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KevinON Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 3:29am
Gatordoc, do you just put some in and run it like you would with diesel?  How long?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:45am
I cleaned a case loader trans with a blown trans cooler i filled it with 50/50 fuel and oil and ran it 10 min and drained and then did the same with  ATF
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2011 at 6:47am
Be sure to run hyd functions when running to flush any cyls. and valves
This page was generated in 0.149 seconds.
