Hydraulic Problems |
Austin(WI)
Joined: 11 Sep 2009 Location: Wisconsin Points: 1474 |
Topic: Hydraulic ProblemsPosted: 30 Apr 2010 at 8:23pm |
On our D-19 the auxillary Hydraulics are sooooo sllooooowww! We had a 12 ft disk hooked up..i bet it took about 30 seconds to raise it up. they are so slow. What is going on? The Arms raise up real fast and hold pressure. But the aux. are very very slow.
"Better By Design"
CTuckerNWIL
Posted: 30 Apr 2010 at 8:47pm |
What kind of cylinder are you using? I'm not familiar with the 19 but if it has the high pressure low volume set up, you need an Allis one way (small displacement ) cylinder. If you use a regular say 4 inch it will take a long time.
Dans 7080
Posted: 30 Apr 2010 at 11:19pm |
Our D19 will do the same thing if you use a oneway cyl (AC CYL). It will run a two way just fine. Dad said it has never ran a one way right, and ive have never seen it run it right either. I had it hooked to a 13 ft disk it wouldnt raise it hardly at all (one way cyl) with a two way, up and down like clock work. My advice is put a two way on it and you should be fine
Austin(WI)
Posted: 01 May 2010 at 4:41pm |
It is a two way.
"Better By Design"
Austin(WI)
Posted: 01 May 2010 at 10:57pm |
I don't even think it works good with a one way either...
"Better By Design"
CTuckerNWIL
Posted: 02 May 2010 at 8:57am |
Austin, I would try to find an Allis one way remote cylinder to borrow from somebody to figure out what is wrong. An Allis high pressure cylinder takes way less oil to extend (therefore extends faster) than any SOB 2 way cylinder.
Posted: 02 May 2010 at 9:56am |
Connect the SAME 2-way cylinder to the tractor and see how fast it works when not connected to the disc (no load)....if the speed is good, you must have a relief valve problem with the tractor. You say the lift arms go right up?? but they're not lifting anything...try the 2-way ram with no load. |
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 02 May 2010 at 10:42am |
Possible coupling or inside hose restriction.
D-17_Dave
Joined: 11 Sep 2009 Location: Mocksville NC Points: 990 |
Posted: 02 May 2010 at 12:02pm |
As Bob said, look for a restriction somewhere in the coupling or hose. Also if your using a 2 way cyl. with one hose you must open the other end of the cyl. to vent. |
