Hydraulic fluid for 210 |
Kevin210
Topic: Hydraulic fluid for 210Posted: 03 Jul 2022 at 8:53am |
I have looked in my book and don't seem to be able find what weight fluid to refill with.
Drained the old oil and going back with new fluid. What is best for this tractor. |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7569 |
Posted: 03 Jul 2022 at 9:12am |
AGCO 821 or equivalent
DougG
Posted: 03 Jul 2022 at 9:52am |
Pure Flo 334,
Joined: 11 Sep 2009 Location: illinois Points: 89144 |
Posted: 03 Jul 2022 at 12:31pm |
The local Farm Store or other will have a couple varieties of "hydraulic oil"... There is the CHEAP STUFF that has little or no specs to it... There will also be a "PREMIUM" type of UNIVERSAL TRACTOR TRANS/ HYDRAULIC oil... Look at the SPEC on the back.. Should list ALLIS 821.. and several others like CAT, JD, ALLISON, CASE..... if there are 20 deifferent "specs" then its good quality and acceptable.... You might also get a AWG 46 hydraulic oil from NAPA or other that meets many specs............. almost everything is like a 20 wt oil.
Posted: 03 Jul 2022 at 12:43pm |
EXAMPLE........
Traveller 590901 Premium Universal Tractor Trans/Hydraulic Fluid is a specially formulated, premium multigrade (SAE 10W-30) fluid blended with the highest quality lubricating oils and the most technologically advanced additive system.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8731 |
Posted: 03 Jul 2022 at 1:13pm |
I picked up some Travelers at Tractor Supply
DougG
Posted: 03 Jul 2022 at 3:31pm |
IMO Travelers seems to thin out when it gets hot
Posted: 03 Jul 2022 at 4:00pm |
Travelers is a 10w 30 type oil... so YES, it is thinner when hot than cold... But "in theory" it is a 10W oil when cold and a 30 wt oil when hot... so should be OK compared to a standard 20 wt oil ???
SteveM C/IL
Posted: 04 Jul 2022 at 9:49am |
I'm curious to know how you came to that conclusion.
DougG
Posted: 04 Jul 2022 at 11:09am |
Of coarse oil get thin when hot ,,,, Got a 6060 with a loader on it - all worked great at first- running it a few hours loading manure- after 2 hours hydraulics got slow - drained that stuff out, replaced with differt brand and good too go - Ill admit money was tight then - this stuff was cheap , found out why, also froze in winter- like gooo- this is my experience
Edited by DougG - 04 Jul 2022 at 11:14am |
