Hydraulic Connections for D17 IV Loader
rhartwick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rhartwick Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Connections for D17 IV Loader
    Posted: 12 Apr 2011 at 6:35pm
I just re-acquired our old D17 IV.  The PO mounted an aftermarket loader with hydraulic bucket, using the single rear remote outlet.  He operated it by wiring the remote lever forward.  The loader has its own set of dual hydraulic controls for the loader/bucket operation.
My question is, can I re-plumb the hydraulic system so the that loader can operate independently with the live pump, so I don't have to cludge the hoses to the rear remote?
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 8:26pm
we have a IV with a loader and we intercepted discharge lines on the side mounted pump. The hydraulics are live (clutch does not affect use of the loader).
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2011 at 10:07pm
IF your loader valve has a relief valve in it, you can run from pump to loader valve IN port and out from OUT port to IN port of tractor valve. If loder valve DOES NOT have a  relief valve don't hook it up.   MACK
This page was generated in 0.095 seconds.
