hyd question, 190 xt
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: hyd question, 190 xt
    Posted: 07 Jan 2011 at 10:40pm
Just wondering how to set up the hydraulic detent on my 190 xt. I am now pulling a feeder wagon with it that has a hydraulic driven discharge chain, and I need the one hydraulic remote to stay engaged without holding it. I'm not talented enough to hold the hydraulic lever back, operate the pd clutch, and steer it all at the same time. Using a tarp strap for now, but I don't like that just because it ain't right. Thanks in advance, Darrel
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 11:34pm
Switch your hoses around and push the lever all the way forward.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 1:46am
i move the lever all the way forward too, also put a tarp strap on for "just in case"
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 6:21am
Under the platform (directly underneath the console) you find the control valve and remove the rubber plug and using a small flat blade screwdriver tighten the detent screw until it is enough to keep the lever from popping out (do this in the "hold" position). This is outlined in an owners manual for the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 10:42am
Dave and shameless, all of the way ahead does lock in, but that is the "float" position. I'm going to find the detent screw and tighten it up. Thanks for responses. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 11:02am
This is off a 200 but should be almost identical to a 190XT.  You can see the rubber plugs on the 3 spools in the pic.  Mike
Edited by Skyhighballoon(MO) - 08 Jan 2011 at 11:09am
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
