HP increase
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Topic: HP increase
    Posted: 10 Feb 2010 at 3:22pm
on my D-19D and D-21 was wondering if a guy could increase HP by improving air flow to intake manifold, by removing pre heater assy and replacing with a plug. seems to me you would have increase air flow by removing the restriction.  what do you guys thunk?
Cowboy UP
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 3:32pm
Brian we had a 7080 that put out 225 horses plus by having a turbo built and putting a little more fuel to it and turning the rpms down so if you can increase the air flow I think it will help just my two cents Niel
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 3:55pm
no, will not make any difference, noda , zilch, now if you were talking nat asperated, at 9000 rpms,,,,,
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 4:01pm
Don't think it will help but i guess it couldnt hurt. The only way your gonna increase hp with  more air is a bigger turbo but then you gotta have a little more fuel to spin that puppy.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2010 at 4:42pm
Has anyone put a boost gage on one to see what pressures they are capable of? I know mine really starts to sing when the smoke starts pouring out of it.....I don't think it has an air flow problem.
ALLIS EXPRESS!
This year:
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 2:03pm
My D21 tops out at 20psi of boost and dynoed at 185 hp at 2200 engine rpm, the thing is it smokes less when you work it because it is finally getting enough fuel when under load to spool the turbo up and burn more of the fuel.  Turbo is an aireasearch to4b 9096 (same as a 7060 supposedly), and the pump was supposed to have been turned 20% by the place that rebuilt it, apperantly it is running a little more though.  General rule of thumb I'm told is for every pound of boost you should have 10 horsepower, but not every engine responds the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 9:51pm
7030-40-45-50-60 turbo has a more efficient compressor wheel than a D21/210/220 and will smoke less due to more air pushed into the combustion chamber.
