How wide is to wide
blazen orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blazen orange Quote  Post ReplyReply Direct Link To This Post Topic: How wide is to wide
    Posted: 14 Mar 2022 at 6:24pm
Putting a set of rims together for 18.4 38 tires and was hoping to some info on rim width for best results thanks
brad7066 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brad7066 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2022 at 10:12pm
what worked best for me was if its a 16.9 16 inches 18.4 18 inch rim. was told that on a deep tread radial you could go a inch wider. also it may differ if you are pulling in light weight classes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote blazen orange Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2022 at 6:40am
The tires Firestone sat ll for a 8000 lbs class.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2022 at 6:57am
Last summer I was using a friends set of 18.4X38 tires mounted on 20" rims. In my opinion I though that was too wide. The rims I made for my own 18.4X38s turned out to be 17" and that seems to work well. I noticed that even with very high pressures the 20" rim allowed the tread to rise up in the middle of the dig outs at the end of the pull.
This page was generated in 0.219 seconds.
