How to remove the Throttle Quadrant on a WD |
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1775 |
Thanks(1)
Topic: How to remove the Throttle Quadrant on a WDPosted: 12 Jun 2014 at 7:34pm |
This how-to article explains how to remove the aluminum throttle/hyd quadrant on a WD without removing the levers.
Start by removing the pin in the steering U-joint. This pin is pressed in and some of them can be stubborn to remove. 60% of the pins I have tried to remove, needed partial drilling to get punched out. 40% I punched out without any drilling. If there is a bolt instead of a pin, its your lucky day. Normally there is an engine in the tractor and the pin will be difficult to punch/drill out, but it can be done. It will be easier when the magneto or distributor is removed. It will be even easier yet if the magneto drive/governor section is removed.
Then slide the steering wheel and shaft out of the support post and quadrant. Remove the bolts that hold the quadrant to the steering support. Next loosen the quadrant from the steering support. Then remove the friction blocks from the levers. Some may need a bit of persuasion to slide off. Turn the levers so they are both pointing down. Next, pivot the quadrant so the top moves back and and slide it down off the levers. When installing a different quadrant, follow the procedure in reverse. |
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
CTuckerNWIL
Posted: 12 Jun 2014 at 8:12pm |
Never would have thought it would come off that way.
fixer1958
Posted: 12 Jun 2014 at 8:24pm |
Nice thought process.
Your hand got dirty though. |
den/southern illinoi
Joined: 11 Sep 2009 Location: Sparta, Illinoi Points: 2090 |
Posted: 12 Jun 2014 at 9:04pm |
Definitely works, been doing it that way for several years. Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor. |
GT in Indiana
Posted: 12 Jun 2014 at 9:06pm |
Pretty slick! I was almost there but didn't think of turning the control arms down
Great post... |
1955 WD45 we like to call Ruby
macvette
Joined: 13 Jun 2011 Location: nekoosa, wi Points: 1658 |
Posted: 12 Jun 2014 at 10:46pm |
Appreciate your posts, Alex. Thanks.
Installed the quadrant quite a while ago that I bought from you, and yes, removing the pin from the steering u joint was miserable. Used a bolt with ground down head and nut when reinstalling,tho! (my WD does no work for its living, tho.)
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8944 |
Posted: 12 Jun 2014 at 11:10pm |
That quadrant still has the lines/grooves!
Jacob (WI,ND)
Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1249 |
Posted: 13 Jun 2014 at 9:15pm |
Good to know! and EXCELLENT article!! This is exactly what we need more of, thank you for putting it together!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
Alex09(WI)
Posted: 10 Mar 2016 at 11:06pm |
Moderator: Would this post be accepted in the "Knowledge Base" Section?
www.awtractor.com
CTuckerNWIL
Posted: 11 Mar 2016 at 7:42am |
Brian Jasper co. Ia
Posted: 11 Mar 2016 at 1:02pm |
Thanks for posting this. I have a WD that needs one badly.
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 11 Mar 2016 at 3:34pm |
Thanks, I need to do that.
BradH
Joined: 28 Feb 2016 Location: Corydon Ia. Points: 264 |
Posted: 11 Mar 2016 at 4:31pm |
Happened to be looking through and notice this topic. Need to do this on mine pretty bad but wasn't looking forward to the job. Was thinking about asking on here soon. Perfec timing, Thanks.
Warning! Blind man with a tractor! Head for the hills!
LaJaMe
Joined: 14 Sep 2014 Location: wisconsin Points: 172 |
Posted: 09 Jul 2017 at 12:58pm |
Thanks for the post. I have a wd that needs one.
Moderator: Could use a post on adjusting the hand clutch on a wd and wd45. Thanks
