Forum Home Forum Home > Allis Chalmers > Farm Equipment -Knowledge Base
How to remove the Throttle Quadrant on a WD
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Topic: How to remove the Throttle Quadrant on a WD
    Posted: 12 Jun 2014 at 7:34pm
This how-to article explains how to remove the aluminum throttle/hyd quadrant on a WD without removing the levers.
Start by removing the pin in the steering U-joint. This pin is pressed in and some of them can be stubborn to remove. 60% of the pins I have tried to remove, needed partial drilling to get punched out. 40% I punched out without any drilling. If there is a bolt instead of a pin, its your lucky day.
Normally there is an engine in the tractor and the pin will be difficult to punch/drill out, but it can be done. It will be easier when the magneto or distributor is removed. It will be even easier yet if the magneto drive/governor section is removed.
Then slide the steering wheel and shaft out of the support post and quadrant.
Remove the bolts that hold the quadrant to the steering support.
Next loosen the quadrant from the steering support.
Then remove the friction blocks from the levers. Some may need a bit of persuasion to slide off.
Turn the levers so they are both pointing down.
Next, pivot the quadrant so the top moves back and and slide it down off the levers.
When installing a different quadrant, follow the procedure in reverse.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 8:12pm
Never would have thought it would come off that way.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 8:24pm
Nice thought process.
Your hand got dirty though.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 9:04pm
Definitely works, been doing it that way for several years.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 9:06pm
Pretty slick! I was almost there but didn't think of turning the control arms down
Great post...
1955 WD45 we like to call Ruby
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 10:46pm
Appreciate your posts, Alex.  Thanks.
Installed the quadrant quite a while ago that I bought from you, and yes, removing the pin from the steering u joint was miserable.  Used a bolt with ground down head and nut when reinstalling,tho!  (my WD does no work for its living, tho.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2014 at 11:10pm
That quadrant still has the lines/grooves!
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2014 at 9:15pm
Good to know!  and EXCELLENT article!!  This is exactly what we need more of, thank you for putting it together!
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2016 at 11:06pm
Moderator: Would this post be accepted in the "Knowledge Base" Section?
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 7:42am
It is there now. Big smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 1:02pm
Thanks for posting this. I have a WD that needs one badly.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 3:34pm
Thanks, I need to do that.
BradH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BradH Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2016 at 4:31pm
Happened to be looking through and notice this topic. Need to do this on mine pretty bad but wasn't looking forward to the job. Was thinking about asking on here soon. Perfec timing, Thanks.
Warning! Blind man with a tractor! Head for the hills!
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 12:58pm
Thanks for the post.  I have a wd that needs one.
Moderator: Could use a post on adjusting the hand clutch on a wd and wd45.  Thanks
This page was generated in 0.251 seconds.
