How to remove cam gear on 190 gas anyone done this
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: How to remove cam gear on 190 gas anyone done this
    Posted: 22 Feb 2011 at 8:11pm
Is there any way to remove cam gear without removing cam shaft itself. I have tried but no luck so far.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 8:44am
Removing the gear might be the easy part,getting it back on would be the hardest I think. I would drop the oil,take valve cover off,get push rods out,remove engine,take off clutch assembly,set engine down on the flywheel,remove pan and oil pump,push lifters up into their bore and then lift cam straight up out of block.I would check crank bearings and cam bushing condition ,oil pump wear and clutch condition too.Good Luck
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 9:29am
Use wooden dowels of the correct size to hold lifter up without removing engine. Use rubber bands on every two dowels to keep the lifters from falling back down.
Wink
I am a Russian Bot
FHOliver View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FHOliver Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 11:53am
WE did it at the dealer many years ago without removing the cam. Was not easy, I think the gear was put in a pan of boiling oil and installed hot with some gentle persuasion, again it was 35 yrs ago and I dont remember all the details, except that it was done. good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 1:08pm
Lonn,that procedure will work if the engine has a crank driven oil pump.If it's a cam driven pump,you need to remove pump before cam will come out.I'm not real sure what engine he has in that gasser.It may not be original,might be a combine.He should be able to see if it is a crank driven oil pump from the front view.If it is, then your suggestion will definately work.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 1:13pm
I was able to get one off of a 262 and they are pressed on also. It's been along time ago but I used a puller in the holes of the gear I think.To put it on Is there a threaded hole in the cam if there is just put allthread  in it and a pipe bigger than the hole and turn it down. I would put camgear in oven at 500 or so like one of my manuals said to do with the D17 camgear.
B212,716,two 314H's,WC,WD,D19,190XT
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2011 at 1:24pm
sounds like the old Ford flathead timing gear, press fit and in then origonal was a fiber gear. To remove: the hub of gear was hand drilled in a couple places to relieve tension from sweat /press fit, then pulled off. Then new gear hub was heated to press back onto cam.
This page was generated in 3.699 seconds.
