how to narrow rims?
acben20 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acben20 Quote  Post ReplyReply Direct Link To This Post Topic: how to narrow rims?
    Posted: 14 Feb 2011 at 6:07pm
does anyone know the best way to narrow a rim i would like to make them 2 inches narrower how do you do this? thanks~!
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 6:11pm
What type of rim Ben? It depends on the profile and type of center.Some are easy some are not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2011 at 6:31pm
I couldn't find rims narrow enough to suit me when I started working on the 35WC(front wheels). I bought a set of blank rims and set them up in the welding lathe. I clamped a plasma torch in place of the welding tip and proceeded to cut all the way around the rim. I moved over 1 inch and cut around again. I put the 2 halves together on the welding table and tacked them where I wanted. Remounted the rim in the lathe and welded all the way around. I burned through enough that just a little grinding cleaned up the exposed part and after paint you can't tell they were ever worked on.
