How to make a G a "high Crop" |
Corbincdc
Joined: 02 Jul 2010 Location: Ames, Iowa Points: 16 |
Topic: How to make a G a "high Crop"Posted: 11 Jan 2011 at 4:43pm |
I grow vegetables on raised beds and need a bit more clearance with the bottom of my tractor and my cultivation equipment. I have been thinking of two things. First, I could get larger rims and tires. I have also seen people modify the axles? Do you know of any resources? Thanks
Corbincdc
Posted: 11 Jan 2011 at 4:57pm |
Oh the Tractors are G's
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5060 |
Posted: 11 Jan 2011 at 5:15pm |
Here's a picture. Dusty
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4903 |
Posted: 11 Jan 2011 at 8:20pm |
this won't be a store bought thing, you will have to build it you're self
Here's some food for thought- ![]() ![]() ![]() ![]() |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Herb(GA)
Joined: 15 Sep 2009 Location: United States Points: 1039 |
Posted: 11 Jan 2011 at 8:39pm |
Corbincdc; please remember that all "hi-crop" tractors have a significantly higher center of gravity (than normal tractors), and therefore are more vulnerable to rolling over when operated on a hillside, or going through a ditch, etc.
CTuckerNWIL
Posted: 11 Jan 2011 at 8:42pm |
Why not bolt a set of B or C finals on and then add your wheels?
JoeM(GA)
Posted: 11 Jan 2011 at 8:46pm |
seen that before -
from the 2010 G roundup ![]() |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 11 Jan 2011 at 8:48pm |
Ok this may sound odd but..
If the beds are just '1 G wide', could you add concrete blocks or 8by8 timbers along the edges to lift the G up higher?
yeah, I know silly idea, jes another way of looking at it !
CTuckerNWIL
Posted: 11 Jan 2011 at 8:52pm |
So if you used C finals, would the 30 inch G wheels bolt up. If not you could alter the wheel centers to make it so.
I would think, if you add the B finals and leave the 24's on it, you would be REAL slow in granny gear. Edited by CTuckerNWIL - 11 Jan 2011 at 8:55pm |
Joined: 11 Sep 2009 Location: illinois Points: 89316 |
Posted: 11 Jan 2011 at 10:09pm |
yea, and just the opposite when you add bigger 30-36-38 inch tires. Your speed will increase by the ratios of the diameter. For instance, if you have 24 inch tires and low gear is 2 MPH, if you install 36 inch tires that is 50% bigger so you will go 50% faster or 3 MPH.
CTuckerNWIL
Posted: 11 Jan 2011 at 10:15pm |
All I was thinking is, if you start out with 30 in tires and have the normal speeds, if you add the C finals with their normal gear reduction, the tractor would be slow with 30 in wheels and even slower with the 24's.
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 11 Jan 2011 at 11:26pm |
By putting on the B or C axles, wouldn't you also have to flip the ring gear? Is that possible on a G? I know guys used to reverse WC's all the time.
Allis Express participant |
CTuckerNWIL
Posted: 12 Jan 2011 at 7:16am |
I guess you would John, I hadn't thought about that.
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 12 Jan 2011 at 11:02am |
I use concrete railroad ties for my raised beds....just drive the 175D up on them and drop the Howard rotovator for a one pass job. I then plant everything close together so it shades out the weeds....just takes a little work with a hoe.
ALLIS EXPRESS!
This year: |
Corbincdc
Posted: 13 Jan 2011 at 12:10pm |
Thanks guys. I'm thinking I will go with the bigger tires and rims and modifying the front end. Similar to Joem's first post third picture down. What size do you think those tiers are? I was thinking maybe 13.6 by 38? Could I go bigger? Besides modifying the rims and front end are there any major concerns?
Corbincdc
Posted: 13 Jan 2011 at 12:25pm |
I was also looking a a 9.5 x 42?? What's your thoughts? too big?
Corbincdc
Posted: 13 Jan 2011 at 12:33pm |
Also where would I go to find a rim for a 9.5 by 42 tire
CTuckerNWIL
Posted: 13 Jan 2011 at 1:06pm |
http://www.millertire.com/
Go to rear rims: then flat base and you will find 10-42 or 8-42.
acgman
Posted: 13 Jan 2011 at 5:18pm |
Our G Hi Crop has 7:00x36 rears and 4:00x15 fronts. If you ever by Muscatine ia. we are just across the river by Joy Ill. and you are welcome to take measurements off it. Thanks Dave.
AKA.ON
Joined: 16 Sep 2009 Location: Shelburne On. Points: 50 |
Posted: 13 Jan 2011 at 9:57pm |
Is that row crop G factory? That is one cool looking tractor.
D12 Series II, D12 Series III, 170, B, U, WC forklift, Cockshutt 40.
