How to get good access to powermax dash
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: How to get good access to powermax dash
    Posted: 01 Sep 2015 at 6:46am
I'm trying to replace my ignition switch and there is absolutely no room to come in from the engine side.  how have you guys done it in the past?
Thanks!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2015 at 9:04pm
I changed mine out some years ago.  Can't remember exactly how I did it.  I think I took the ammeter out and worked through the hole in the dash...
Good luck to you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2015 at 9:44pm
Take off steering wheel and raise the dash up after removing screws. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2015 at 6:20am
Tracy, what is the safest way to remove the steering wheel without damaging it?  Is the cross bolt the only thing holding it on besides splines?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2015 at 2:03pm
Dave,
On my 620 my steering wheel came right off. Took out the through bolt and the wheel came right off! The top part of the dash lifts after you take the screws out like Tracy said. It's a bear to git' yer' hand in there especially with the support brace that's part of the control panel. Sheesh!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2015 at 2:25pm
Like Steve said, steering wheel will come right off. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 03 Sep 2015 at 9:25am
apparently i just had to get a little aggressive and the wheel popped off.  Thanks guys
