How to change D17 camshaft? |
rr4406pak ![]() Bronze Level ![]() ![]() Joined: 16 Nov 2010 Location: Marion, NY Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 16 Nov 2010 at 11:38am |
Just found that my camshaft has a broken oil pump drive gear on my
gasoline D17 *sigh* (I think it is a series 3 have to check the serial number). So I have to change the camshaft. The oil pump
gear is perfect (I do wonder how the heck the oil pump gear can be
perfect and the cam gear absolutely destroyed? Oh well, anyways...)
My questions are: 2. I assume changing the lifters is mandatory? 3. Is this a very difficult job with the engine still in the tractor (I'm not the best mechanic but I have changed the cam in a car before)? I know I have to take the radiator off. What else needs to be removed on the front of the engine? Any tricks? 4. I would like to buy a shop manual so I know what I"m doing when disassembling and reassembling. What is a good manual to buy? Help is greatly appreciated and Thanks in advance!Keith |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22823 |
By a manual from Darin to help support this site.http://www.3000toys.com/allis/manuals.asp
It's going to be a bunch easier to change the cam with the engine out and turned upside down. The lifters cannot be removed with the cam in place. If you can figure out a way to keep the lifters up in their bores, it can be done. I'd pull it if it were mine. If the cam gear bit the dust, how long did it run before you saw the oil gauge at 0? It'll be easier to inspect the rotating assy for lack of oil damage with it out on a stand. Getting a shop manual would be a very wise first step. |
Pulling the engine is not an option for me. I don't have the facility to do such a thing.
I have to change the cam with the engine where it sits. As to how long I ran it with zero oil pressure? I'd have to say (I'm guessing) a few years. Engine runs smooth. I always thought the oil pressure gauge was just broken. Stupid me... Have not looked at the rockers or upper valve-train yet. I might be in for a surprise there too. I have got to change this cam. The I.T. book will be my first purchase. Winter is coming and I do not have a heated garage. It might be best for me to wait until spring if the job is really complicated... |
mlpankey ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Vols country Points: 4580 |
the engine has to come out and at least lay on its side or next option is to be real creative with tie wire to push each lifter up off the cam lobe as you pull the cam out the front of the engine. then theres the cam bearings so the engine needs to be pulled.
Edited by mlpankey - 16 Nov 2010 at 1:40pm |
Why can't I use the old cam bearings?
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
Pull out push rods then find wooden dowels that fit fairly tight into the lifters. Push them into each lifter. Lift each lifter up to clear the cam and put a rubber band around every two dowels. This will hold them in place. Now you can pull the cam shaft. Old mechanics trick and it works.
Edited by Lonn - 16 Nov 2010 at 2:16pm |
Wink I am a Russian Bot |
gcalent ![]() Bronze Level ![]() ![]() Joined: 19 May 2010 Location: Willards, Md Points: 179 |
I agree that the proper way would be to remove the engine and turn it upside down, BUT you can remove the cam in the tractor. As you have figured out you will need to remonve the timing cover from the engine. The lifters can be held in place, after removing the valve train, by using a wooden dowel that fits tight into the lifter bore. Tap the dowel in to the lifter and hold in place with a small spring clamp. After removing the cam the lifters can be removed from the botton if desired. The cam bearings in these engines are brass and are pretty tuff, so you may be able to reuse them, you not doing a total rebuild just trying to get it back operational.
Pullin With AC
Thanks for the tips!
Will I have to remove any steering or front axle parts to get the cam out? |
If I remember correctly, the shop manual says to take the front pedestal off to remove the oil pan. If you have p/s, the ram definitely would hinder you getting the pan off. I'm not sure how tough it would be to remove the front pulley or if it can be done with the pedestal on it.
I don't have powers steering and I already have the oil pan off.
The only thing I had to remove to get the oil pan off was the starter. I sure hope I don't have to remove any front end parts (besides the radiator). Fingers crossed! |
Chris (swIA) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
Yes it can be changed without pulling the engine. I just did this on mine due to govenor weights going throught the timing gears. You have to pull the front end off so you can pull the crankshaft pulley, front engine support, and then the timing cover. Just block it up securely under the torque tube. An extra pair of hands would have been helpful putting the cam back in and trying to hold up the lifters though.
I use closepins in the dowl s to keep the lifters up. MACK
