how much motor
bigcountry48 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountry48 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 5:47pm
It's gonna be pretty fast with that stocks rearend so hold on lol!!!
1950 B, 1952 pulling wd, and 1954 wd45
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 6:10pm
The ground speed chart i got from the antique tractor pull guide had 1st gear at 4.17 mph
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 6:30pm
My math says 4.2 MPH @ 2100 RPM's with a 13.6 X 38 (60 inches tall)rear tire in a WD-45 low gear. Which is 2.8 MPH @ 1400 RPM rated speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 6:36pm
Thank you dr i will have to measure the height of my tires to figure out how much my ground speed will increase
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 9:10pm
312 ci will be a big help. 10.5-1 comp.-ro will also be a help if you can run a good enough fuel to use the 10.5 - 1.
 A good MSD ing. would also be a help.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2015 at 9:12pm
I run 112 octane vp fuel and have electronic ignition along with the 55,000 volt thunder volt coil
