how much motor |
Page <12 |
bigcountry48
Posted: 04 Jan 2015 at 5:47pm |
It's gonna be pretty fast with that stocks rearend so hold on lol!!!
1950 B, 1952 pulling wd, and 1954 wd45
allispuller
Posted: 04 Jan 2015 at 6:10pm |
The ground speed chart i got from the antique tractor pull guide had 1st gear at 4.17 mph
Posted: 04 Jan 2015 at 6:30pm |
My math says 4.2 MPH @ 2100 RPM's with a 13.6 X 38 (60 inches tall)rear tire in a WD-45 low gear. Which is 2.8 MPH @ 1400 RPM rated speed.
allispuller
Posted: 04 Jan 2015 at 6:36pm |
Thank you dr i will have to measure the height of my tires to figure out how much my ground speed will increase
MACK
Posted: 04 Jan 2015 at 9:10pm |
312 ci will be a big help. 10.5-1 comp.-ro will also be a help if you can run a good enough fuel to use the 10.5 - 1.
A good MSD ing. would also be a help. MACK
allispuller
Posted: 04 Jan 2015 at 9:12pm |
I run 112 octane vp fuel and have electronic ignition along with the 55,000 volt thunder volt coil
Page <12 |
