How look up what year an engine was built?
AllisHunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Topic: How look up what year an engine was built?
    Posted: 07 Jan 2022 at 2:09pm
Can you use the serial number to look up an engine somewhere online? Thanks.
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2022 at 2:34pm
No records were kept of that. You can generalize baised upon tractor number with certain engines. but the futher up you go in any tractor the more you can be off because of power units not used in tractors.
Edited by Butch(OH) - 07 Jan 2022 at 4:39pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2022 at 3:27pm
http://wsmth.people.clemson.edu/SNFind/esn_tsn1.htm
this will look like a BAD link when you click on it... several lines below that is says "here is the document"... click on that....... He has tried to match tractor numbers, engine numbers and years for various Allis tractors.
when you get to the ALLIS B page, you can click on "SN MAIN PAGE" or "HOME" below the title and go backward to other pagers..
Edited by steve(ill) - 07 Jan 2022 at 3:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisHunter Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2022 at 4:00pm
Thank you!
GreenOrange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GreenOrange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2022 at 4:58pm
There are also casting numbers that can get you close and some casting date codes, at least for some models. What model are you researching?
