how do you paint?
abbaschild95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Topic: how do you paint?
    Posted: 31 Mar 2011 at 11:25pm
i know im going to get a million different answers for this and many saying it is up to the painter... but how to you paint your tractor? do you paint each individual bolt or do you put them where they go then just paint over it?? all comments are helpful! thanks!
Great-granfather's WC---- hopefully many more to come!
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 7:17am
I will bump you back up and give the first general answer...depends on how 'good' you want it to look. I know you are looking for technique, I do not have that.
hope you get some helpful answers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 7:18am
guess I'll get the ball rolling...
Painting is the easy part, the details and quality is in the prep !
Currently I'm d0oing a G,so all the tin(actually everything that fits,rims are fun to do !) comes off and goes into the electrolysis tank to get rid of rust and old paint,things like pedal arms,levers,nuts,bolts,etc. all get power wirebrushed.Everything gets cleaned with laquer thinner and compressed air dryed, twice,then several coats of white Kylon primer on a warm and sunny day(soon I hope).Tires come off rims,inside surfaces, once clean get 2 coats of hand brushed Tremclad galvanise(sp) paint or enamel over 3 days.
Before even thinking of painting the 'engine-tranny-rearend' section, fix EVERY leak,then clean and wait 2 days,test for leaks again.Once you're sure NO leaks, then paint on white primer, wait a day,check for leaks(you'll KNOW), then paint colour on.I do spray nuts and bolts separately,seems to keep light rust from weeping down later(fender mounting area).My tractors work here, get caught in the rain.As for type of paint, a good automotive single stage is Ok for me.None of my tractors will place 1st in show,so colour/clear is not necessary.
Just some of the steps I do....just remember 90% of your time should be on prep,No amount of paint will hide 'things that I shouldv'e done'...
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 8:53am
I take off the sheet metal items and hang them up. Pressure was every thing take off wheel and set tractor on blocks esay off the entire tractor wash againg degrease and paint it sitting outside the barn on a warm summer day. The sheet metal parts I prime before paint. My Tractors only get used around the house so no show winners here.
I've just been using Valspar implement Paint Looks good to me and the Valspart Spray cans match. I have to touch up a few bolts after assembly.  After a year of throwing chains and tools on the tractor  The step and diff housing show a few scraches.. but it still looks good. I plan on painting anothe rthis summer usung the same technique.  I V'e finished the mechinical repairs on it already and run it about 6 months to make sure its all fixed before painting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 9:30am
Sandblasting gets all the rust, old paint, and dirt off. You have to take precautions to keep sand out of things you don't want sand in like the trans, engine, etc. The way I do it is pack grease around shaft seals and cover with duct tape. I do the same with the shifter boot and engine openings. If the sand gets past the tape, (you don't blast right on the tape) the grease stops it from going any farther.
Fix all mechanical problems before painting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote abbaschild95 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2011 at 12:29pm
so what i have been doing so far is pressure wash the entire tractor, disassemble piece by piece fixing everything as i go. i sandblast every bolt and nut... everything. i just wasnt sure if i paint each bolt individually.... would a less quality paint on the bolts and then paint over everything when im done work to prevent rust and still look good? thanks for the input!
