How do I Loosen TRACKS on HD91965
BillRO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Topic: How do I Loosen TRACKS on HD91965
    Posted: 15 Sep 2014 at 6:18pm
How do I Loosen the TRACKS on a 1965 HD9B, Thank you for your help
Edited by BillRO - 16 Sep 2014 at 1:30am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2014 at 8:07pm
The big rod pushing the idler ahead on the track frame is threaded on the back .The front has a hex to let a wrench get a bit on it.Most likely will have pipe wrench marks behind the hex.The  HD5 of the same age have a trapezoid shaped nut that has 2 bolts that pull the nut back locking the shaft from turning with vibration. I don't remember if the HD9 has the same lock or not but there is a lock somewhere.Good luck as a place where things rust and if not turned in 20 years may take a lot of lose juice and a big pipe on your wrench.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillRO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2014 at 8:58am
Thank you , This has got to be the Worst Design of any
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2014 at 9:19am
All brands used the same system ,and all changed to the hydraulic style at about the same time.The hydraulic adjusters have there problems as well.
This page was generated in 0.275 seconds.
