Hooking plow to a B |
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Apr 2018 at 9:06pm |
I know this question has been asked before. A guy at work just acquired his Dad's B and it has two turning plows with it. He said he couldn't figure out how they hooked up so he asked me if I knew. I said I didn't but I'd try to find out. Any pics or info would be appreciated.
He is supposed to send me some pics of his plows and tractor. I will post them when I get them, that may help. Thanks. |
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88328 |
probably has a PIN on a cross bar below the transmission... then the Rock Shaft lift arms in the back.
setting under the motor and looking backward, the silver pin attaches the beam to a bracket that is hinged on each final drive case... most setups have a lever attached to the bracket so you can raise and lower the front of the beam from setting in the seat... or you can have a solid mount so it will not raise and lower.
1939Dodge ![]() Orange Level ![]() Joined: 18 Jan 2014 Location: Pa. Points: 554 |
I just bought a set of plows and mounts from a C. I want to use it on my B. The crossbeam that mounts between the final drives is too long. I'm looking for the correct beam for a B, willing to purchase, or trade if someone can use it. Thanks!
