Hi-Low range lever on a 220
Kevin210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin210 Quote  Post ReplyReply Direct Link To This Post Topic: Hi-Low range lever on a 220
    Posted: 02 Jun 2024 at 8:10am
Any one know if there's a bushing on the high low
gear lever on a 220..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 8:24am
I don't think so. I do know I have never replaced one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2024 at 10:34am
It isn't like it got much use to wear it from pivoting.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2024 at 7:24am
There is a bushing, but like mentioned, it moves so little, wouldn't think it'd ever wear out. I actually honed the one on mine out and polished the shaft so it will move freely. It shows it on partsbooks I think, and maybe the bushing is still avail if you actually need one. If not in Agco, parts depot would likely have some. Otherwise mcmaster carr has bushing stock to make them from. What is the issue with yours?
