High-low shim D17
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Topic: High-low shim D17
    Posted: 21 May 2016 at 9:06pm
Can someone explain to me how to shim (tighten) H/L on a 59 D17.  First time out to pull this year , did ok in 4000 lbs class but slipped in 4500.  15.5s 120 + hp. 4mph.
 And yes, I know its H/L  that slipped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 5:12am
The service manual gives a very well detailed description and measurements for the process.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 6:47am
Do tell what engine you have in there!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 6:11pm
Start by obtaining LONG shims for the center location on the clutch. I'd order six .020" long shims and six .015" long shims and have them on hand. Remove short shims in LOW or HIGH range and replace them in the center location with LONG shims. Don't let anyone tell you different.
RichinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 7:07pm
4.6 bore 5 3/4 stroke
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 8:55pm
DR. Allis is correct. You need to maintain .205 total shim any way you put it. Access it through the plate by the shifter. Rotate it and loosen it up. Remove from the high, low or both and put the same thickness worth of shims in the neutral set. Neutral shims are long, hi and low are short. They do not interchange. Agco carries them.
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
