High Compression Starter help
GonzoCSU View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GonzoCSU Quote  Post ReplyReply Direct Link To This Post Topic: High Compression Starter help
    Posted: 23 Aug 2010 at 11:49pm
I have been searching the forums and found a lot of good information but not the exact answer I am looking for.  My buddy has a WD pulling tractor which runs great and is very competitive but we keep breaking starters.  We have 3 starters, 2 are standard WD starters and one is a gear reduction starter.  The standard starters will not even turn the engine over a full revolution.  We basically just bump the starter and if the engine is in the right position it will fire and start but if the engine backfires the nose cone on the starter gets broken.  The gear reduction starter keeps shearing the key on the gear off.  We have 2 12 volt batteries wired in parallel so we should have plenty of amps to crank it over.  Someone suggested putting a ignition retarder box on for starting but that won't solve the problem of not being able to turn the engine a full revolution.  Is there a way to build a stronger starter or a starter off a different tractor that will turn this engine over?  Thanks for the help.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 6:55am
wire the batterys  in series it will start . dont let the motor roll backwards clutch it before it luggs all the way down. They are some 12 volt 2.4 kw ccw coils for it also .  the amps of the batterys in parallel will burn the starter up quicker than the in rush of the 24 volts . once the starter turns it will turn faster at less amps on the 24 than it will dragging on 12 volts and high amps.
Edited by mlpankey - 24 Aug 2010 at 7:06am
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 7:07am
By backfire I assume you mean it's kicking back on the starter?  Any old hot rodder with a distributer machine can change things around so your total advance remains the same but the initial will be retarded so it quits kicking back on the starter. Steve NJ comes to mind.  You also need to run fuel up to the task of dealing with whatever your compression ratio is. If its just your compression pressure that breaking the starter none of this applies.
Edited by Butch(OH) - 24 Aug 2010 at 7:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 7:12am
they will pull better and run better if they have the advance locked out and run total timming for a given rpm.  If it has the compression to create starter promblems it shouldnt have enough total timing with the advance locked out to create a starting issue.   400 plus cubes at 15.3 comp ratio no avdance start it fine untill the pull switch burns up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GonzoCSU Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 8:38am
It runs so well I am a little hesitant to start messing with the timing.  I have thought about locking out the timing and getting a timing box for it but I am just trying to take it one step at a time and get a starter that will turn the engine over first.  If I could get a starter that would crank the engine over I could get the engine cranking then hit the ignition.  Any idea where I might be able to find those 12 volt coils?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 9:19am
They are for a 14 mt delco marine starter such as a mercruiser with a 454 bbc  . the 2.4 kw is the high torque coils.   I still run batteries in series and not in parrallel when using these coils also use a stud terminal and a solenoid from warren wench. ford solenoids dont hold up to the 24 volts. remedy to keep the pull switch from burning up they are 30 dollars a piece these days.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 11:59am
in this post i tell how to keep voltage to ignition box to 12 to 16 volts depending on battery used in series
Unofficial Allis Homepage
[Main Page] [Old Forum] [Owners Registry] [Allis Store] [Parts Etc.]
< =dropDownSearch id=dropDownSearch ="quick_search.asp?FID=2" Border=0 scrolling=no>
  FAQ FAQ  Forum Search < = =text/>document.write('Search') SearchSearch  Calendar < = =text/>document.write('Calendar') CalendarCalendar  Display List of Forum Members Memberlist  Logout Logout [mlpankey]
igintion
Dusty MI View Drop Down
Online Status: Offline
Post Options Post Options   Quote&nbsp;Dusty MI Quote  Post ReplyReply Direct Link To This Post Topic: igintion
    Posted: 14 Aug 2010 at 9:02am
Are there any Allis's that have an ignition that starts on 12 volts and runs on 6 volts? If so which model? I'd like to see the wiring diagram for it.
Dusty
917 H, '48 G, '65 D-10 series III
DaveKamp View Drop Down
Post Options Post Options   Quote&nbsp;DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2010 at 5:16pm
None that I'm aware of, but a starter solenoid with an IGN terminal, and a ballast-resistor in the coil primary circuit does essentially that.  Look at any automotive application of the 50's on, and if you see a ballast resistor in series with the primary circuit, you'll see that there's another wire... when the starter solenoid is energized, there's a bypass wire that feeds full available battery voltage to the coil, and when you release the key, the ballast resistor becomes the running current path.
Post Options Post Options   Quote&nbsp;Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2010 at 5:51pm
Thanks Dave that's what I had planned, I think it may need a diode to prevent a back feed.
My ignition switch is getting touchy so I thought that maybe there was a switch that would do the job.
Dusty
Gerald J. View Drop Down
Post Options Post Options   Quote&nbsp;Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2010 at 6:08pm
Standard on new generation JD tractors. 6 volt coil with external resistor for 12 volts. A contact on the starter solenoid supplies 12 volts to the coil while cranking.
You don't need a diode, you need a relay. Something like the $3.95 cube relay sold at most auto stores will do just fine. Wire the coil in parallel with the coil on the starter solenoid (usually one side is grounded and the start switch or button supplies 12 volts). Wire one of the normally open contacts to the battery, and the other to the coil side of the resistor. Or more simply for the contacts, wire them so when energized, the relay shorts out the coil. If wired from the battery to the coil that will let the engine start when the ignition switch has gone bad but it stops as soon as you let off on the start button. My JD 4020 did that while making hay from bad wiring under the dash. I hot wired from the battery to the resistor to keep it running to finish the hay making. Then I removed the &*)(&(*^%$*&^%(*&%^ Scotch tap from the ignition circuit.
Gerald J.
Jim Guarino,Agri-Ser View Drop Down
Post Options Post Options   Quote&nbsp;Jim Guarino,Agri-Ser Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2010 at 11:29pm
The D17 series IV used a bypass ignition with a 6 volt coil and an ignition resistor.
Post Options Post Options   Quote&nbsp;Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 8:45am
Don't ya just love those Scotch loks?  LOL!  One of the main reasons why Trailer wiring doesn't work. Gotta' love these Trailer mfrs the way they wire their products. Cheap, cheap, cheap, fast, fast, fast, is the name of the game I guess. Quality gets tossed to the side, and after a year or so its fix, fix, fix...!!
ernie (ECIN) View Drop Down
Post Options Post Options   Quote&nbsp;ernie (ECIN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 8:50am
I have removed everyone of those connectors for my trailer harnesses and soldered the connections, put a shrink tube on them then tape them with the heavy rubber tape and electrical tape to finish it off. My boys hate this, but I don't have any more problems with the traler connections now.
Online Status: Online
Post Options Post Options   Quote&nbsp;mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 17 Aug 2010 at 10:23am
MY STARTER IS WIRED FOR 28 VOLTS AND MY IGNITION IS ON 16 VOLTS  cause  the msd box cant handle more than 18 volts .  thats a 12 volt battery in series with a 16 volt race battery . The negative on the race battery goes to ground so I can wire the ignition box ground to the negative of the race battery and its positive post and have only 16 volts to the ignition. One set of cells .   can do the same with two six volt batterys . positive of one goes to the starter the negative of that battery goes to the positive of battery two .Battery twos negative goes to the tractor frame keep all 6 volt gauges and switches wired to battery two.
Edited by mlpankey - 17 Aug 2010 at 10:31am
I like pulling against people who dont pay close attention to the little details ,however more are purchasing engines from builders who do.
< =dropDownTopicSearch id=dropDownTopicSearch ="quick_topic_search.asp?TID=16557" Border=0 scrolling=no rel="nofollow">
< id=frmMessage name=frmMessage ="return Check;" =new_post.asp method=post rel="nofollow">
Quick Reply
Message:
< = ="RTE__common.asp" =text/> function FullReply(formName){ document.getElementById('message').value=document.getElementById('WebWizRTE').contentWindow.document.body.innerHTML; formName.action = 'new_reply_form.asp?TID=16557&PN=1&TR=8'; formName.submit(); } < = ="RTE_.asp?=message&QR=true" =text/> WebWizRTEtoolbar('frmMessageForm'); document.write ('< id="WebWizRTE" ="RTE_.asp?mode=reply&ID=1778" width="650" height="100" style="border: #A5ACB2 1px solid" ="initialiseWebWizRTE;" ="2">'); < id=colourPalette style="LEFT: 0px; VISIBILITY: ; : ; TOP: 0px" ="s/RTE__colour_palette.asp" Border=0 width=260 scrolling=no height=165>
Spell Check Insert Hyperlink BoldItalicUnderline Text Colour Full Reply Editor About Rich Text Editor
< id=WebWizRTE style="BORDER-RIGHT: #a5acb2 1px solid; BORDER-TOP: #a5acb2 1px solid; BORDER-LEFT: #a5acb2 1px solid; BORDER-BOTTOM: #a5acb2 1px solid" =2 ="RTE_.asp?mode=reply&ID=1778" width=650 =initialiseWebWizRTE; height=100>
JavaScript must be enabled on your web browser in order to use this Rich Text Editor!
< id=message = name=message> < id=browser = value=RTE name=browser>
   < id=forumCodes =3 = value=True name=forumCodes>Enable BBcodes to format post
   < =4 = value=True name=signature>Show Signature   < =5 = value=True name=email>Email Notify me of Replies
< id=mode = value=reply name=mode> < id=FID = value=2 name=FID> < id=TID = value=16557 name=TID> < id=PN = value=1 name=PN> < id=ThreadPos = value=9 name=ThreadPos> < id=QR = value=1 name=QR> < id=ID = name=ID> < id=pre = name=pre>  < id=Submit =".'message'.value=.'WebWizRTE'....inner;" =6 =submit value="Post Reply" name=Submit> < =".'pre'.value=.'WebWizRTE'....inner; Preview.frmMessage;" =7 = value="Preview Post" name=Preview> < =8 = value="Clear " name=>
Forum Jump < = name=JumpForum> < value="" ed>-- Select Forum -- < value=forum_topics.asp?FID=2&title=farm-equipment> Farm Equipment < value=forum_topics.asp?FID=3&title=construction-and-other-equipment> Construction and other equipment < value=forum_topics.asp?FID=9&title=shows-and-s> Shows and Events < value=forum_topics.asp?FID=8&title=forum-talk> Forum Talk < value=forum_topics.asp?FID=4&title=shops-barns-varmints-and-trucks> Shops, Barns, Varmints, and Trucks < value=forum_topics.asp?FID=5&title=politics> Politics < value=forum_topics.asp?FID=7&title=sup> Support Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.61
Copyright ©2001-2009 Web Wiz
< name=I1 ="http://www.allischalmers.com/sources/banner.aspx" width=900 height=220>Your browser does not support inline frames or is currently configured not to display inline frames.
Ken(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 4:02pm
I know from experience with my military truck that pulling voltage from only one of two batteries wired in series will have an adverse effect on at least one, if not both batteries, no matter how little or how much you take off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 5:00pm
If this engine has big cubes and lots of compression, the total running timing (1500 rpm or more) should be around 12 to 15 degrees BTDC, not 25 to 30 degrees like standard engine timing. So, that being said, if the centrifugal advance is working normally/properly (like it should) the timing would be AFTER TDC when cranking....that is if the advance is working like it should. If the timing is ATDC ( while cranking) I can't imagine breaking the starter nose.....unless the racing gas isn't 114 octane????
Post Options Post Options   Thanks (0) Thanks(0)   Quote GonzoCSU Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2010 at 5:29pm
We are running 110 octane.  I am not sure exactly what the timing is set at.  If I have time tonight (and find someone to help me pull start it) I will take a look at the timing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 7:12am
If you can pull start it . Compression isnt whats keeping the starter from turning.  Ours drags both wheels when trying to pull it off . but the 24 volts to the starter cranks her. If your worried about kens adverse suggestion use a solenoid to seperate the batteries . the batteries will only be hooked positive to negative when the solenoid is energized for starting. If you have more than 12.1 compression you need more octane than 110 advertized you will need a minimum 110 mon which will make the advertized octane rating higher than 110. but dont believe me for i only pull stock allis engines. I just add 7 al 2 ignition boxes and 16 volt racing batteries to it for impressive show and to have something to waste money on. intimidation always beats hp not .lol
Edited by mlpankey - 25 Aug 2010 at 7:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 7:19am
You might try a 12 volt diesel starter and run it on 24 volts.  I think it will bolt right in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2010 at 7:31am
Originally posted by mlpankey mlpankey wrote:
If you can pull start it . Compression isnt whats keeping the starter from turning.  Ours drags both wheels when trying to pull it off . but the 24 volts to the starter cranks her. If your worried about kens adverse suggestion use a solenoid to seperate the batteries . the batteries will only be hooked positive to negative when the solenoid is energized for starting. If you have more than 12.1 compression you need more octane than 110 advertized you will need a minimum 110 mon which will make the advertized octane rating higher than 110. but dont believe me for i only pull stock allis engines. I just add 7 al 2 ignition boxes and 16 volt racing batteries to it for impressive show and to have something to waste money on.Learned last year that msd 6 boxes were only good for compression ratios up to 12.5.1. intimidation always beats hp not .your making more trouble out of starting one than it is . its simple and if you dont believe me you can ask chris  carter also. lol
Edited by mlpankey - 25 Aug 2010 at 7:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 8:17am
I build some kick-ass starter motors for puller tractors. They're not cheap because they're custom built, but they do the job. No complaints yet. Drop me a line if interested......
CJohnS MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 8:35am
You're not the only one - check out this solution:
Has many features:
1. No pesky "nose" to break off
2. Easy visual inspection - even from the operator's seat
3. Expandable - need more torque - add a bracket & another starter
4. Backup power - battery dies - wind a rope around the pulley & give a yank
5. Non-denominational - can use almost any brand starter - the Ford is just one.
In addition, it can be used for:
1. cracking walnuts
2. crimping straw
3. opening the ends of tough potato chip bags
4. zig-zag french fries
5. speed-winding line onto your new open-face deep-water fishing reel
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 8:56am
cjohns that is funny,what a set up!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 9:25am
sometimes whats funny is you give a guy the info on  coils and a battery  configuration that makes a kick ss  starter  and they dont believe .  Maybe he can purchase a john deere G and a belt  to hook up belt pulley to belt pulley surely that will produce enough torque to crank it.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 9:52am
What about a compression release mechanism? I know I used to put them in high compression motorcycles with kick start.
They also work well in chainsaws.
Once the engine starts, the release pops off so it has full compression.
Isn't the same prinicipal used for Jake Brakes?
Edited by Goose - 26 Aug 2010 at 9:53am
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 12:59pm
Jake brake opens exaust valve at top of compression stroke.Wouldn't help much in this situation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 1:03pm
I like Ted's idea for trying a diesel starter. It's got to be stronger built than a gas. Will it fit is the only question.
I have no doubts that Mitch's modifications work well. I would think a diesel starter has a stronger nose cone. Ever tried one Mitch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 1:10pm
no they are too expensive to modify . Gonzo csu said in his first post he had one and was having trouble with it. The only time I  have broken nose cones is from one of two things. 1 leaving starter in bell housing when removing or installing engine. 2 . letting it kick back or roll backwards when lugged . I would love for someone to send me a starter that a single 12 volt 800 cca battery would crank my tractor over . If it would .I would pay them but most want paid immediately wither it works or not . I should say that I have been talking to a custom starter manufacturer who can make a high torque starter just need alot of others with deep pockets to  be interested to get them interested.  So I have been doing what I mentioned above and it works . To say it works well is a matter of opnion . Seams when I get one trouble free I go and increase the compression ratio along with the cubic inches which puts me back to working on ways to make a oem starter work . So far I have been able to.
Edited by mlpankey - 26 Aug 2010 at 1:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CJohnS MI Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 1:26pm
...as specified - 2 JDs on one belt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GonzoCSU Quote  Post ReplyReply Direct Link To This Post Posted: 26 Aug 2010 at 10:44pm
I never said I didn't believe you.  I have a couple starters lying around but I can't seem to find the 14MT coils.
I took the gear reduction starter to a local machine shop to have a second keyway cut into the gear and shaft but they said the gear is hardened so they can't cut a keyway in it.  We are looking into have a new gear made.
We have a starter timing box coming so that should help once we find a starter that will turn the engine over.  In case you are wondering here is a pic.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 6:55am
Again hook the two batterys in series and the starters you have laying around will start it . no need for a timing retard box . how many cubic inches is it . Carb looks small in picture. 400 cubic inches 85 percent v/e  @ 1.5 hg requires a cfm of 206 @2100 rpm to adequately fill the cylinders and updrafts where sized at 5 hg instead 1.5 . ebay complete 14 mt ccw starter 129.00
Edited by mlpankey - 27 Aug 2010 at 7:15am
kendak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kendak Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 9:17pm
sounds like your buddy doesn't know his own tractor...what is his C.R. & cyl. pressure ?...I pulled a 45 with 13.5 to 1 cr. & 325psi. cyl. pressure for 3yrs. & started it with stock starter & a wally world 750cca. battery.....if it kicks back it's got waaay to much timing in it...ran mine at about 8 degrees BTDC  & then got smart & ran it up to 12 BTDC & got 5 hooks in before it cracked all pistons....pull the timing out of it & you'll be able to start & will lug better at the end of the track....take care
NNYACAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NNYACAL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 9:18pm
Haven't heard anyone here mention that Delco offers a bearing kit that goes between the  end of the armature windings and the starter bendix drive. This allows for the fields to be set closer to produce more torque without dragging Also keeps armature shaft from flexing and cracking nose cone.
G,IB,B,C,CA,RC,WC,WF,WD,WD45,D14,D17SERIES 1,2,4
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 1:18pm
well? did you get it started over the weekend?
BCPuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BCPuller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2010 at 3:44pm
What are you using the tank on front for?
cbt1124 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 12:39am
Before you go through all the trouble of finding another "Beefed-up" starter for your tractor, why don't you pull all the plug wires off and try to crank the engine over with no spark. This will show you whether your problem is too much compression or ignition load.I believe you will find out that your problem is with advanced timing. Just my 2 cents!!! Please give it a try and let us know...
Post Options Post Options   Thanks (0) Thanks(0)   Quote cbt1124 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 12:47am
Jake brakes work just the opposite of what you are saying. Jake brakes actually only open the exhaust valves 1/2 of their normal stroke when the engine is in deceleration mode, the moment you touch the throttle or the clutch the Jake brake is deactivated
This page was generated in 0.083 seconds.
